I just installed XMediaRecode 3.1.1.8. So far it seems really buggy. Drop down lists do not expand, cropping and resolution don't update correctly. But the big problem is after I add the job and click encode, it goes to the progress screen for about 1 second, then acts like it finishes. It creates a 0b file in the destination. Does anyone know how to fix this?
Maybe try an older version, https://www.videohelp.com/tools/XMedia-Recode/old-versions#download
Or just use another all-in-one converters like vidcoder, tx264, tencoder, xvid4psp, freemake video converter(adware). -
Thanks. I went back to the previous version I had and it's still not working but it turns out it's something about the input file. I was able to convert another video. The file that it won't convert is an mkv.
From suggestions in the comments part of its tools/downloads entry I installed version 3.0.6.7 and never had any problems.
Thanks Hoser Rob. Maybe I'll upgrade to that. I tried TEncoder too and it had the same problem. Since it has a log I was able to determine it had something to do with the audio channel. I was trying to do a straight copy of video and audio to just basically change the container from mkv to mp4 or mov. If I re-encode the audio instead it works. I thought I had tried that before in XMedia Recode so the latest version may or may not still have a problem with it, but 1.0.9 is doing ok as long as I convert the audio.
Side note: Do you guys know what the Audio / Video Syncronisation checkbox does in XMedia Recode? If I don't check it will they fall out of sync?
Subtitles in Xmediarecode
By dfisher052 in forum SubtitleReplies: 5Last Post: 5th May 2012, 09:35 -
xmediarecode saveerror
By fester77 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2011, 13:11 -
hardsubbing xmediarecode
By fester77 in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2011, 10:49 -
xmediarecode - getting the bitrate I want
By pooksahib in forum Video ConversionReplies: 6Last Post: 7th Feb 2011, 05:06 -
XmediaRecode problem 2.3.0.2
By pepegot1 in forum Video ConversionReplies: 0Last Post: 14th Jan 2011, 22:10
