When I encode videos with handbrake using either the strict or loose anamorphic setting the playback on my T.V. (LG 47LW5700) is the original source size. Example: A video source might be 720x576, when I choose the Strict setting it says the display size will be 1024x546 - which it is if I play it with VLC, but if I try to stream it to my TV from my NAS or play it from a USB drive the original source size is displayed. Is this an issue with my TV or is there some setting in Handbrake I need to enable/disable to get it to playback at the larger display size. I'd appreciate any help anyone can offer![]()
Is the aspect ratio correct BUT the image doesn't fit the screen?
I'm guessing that is the case and if so then it isn't handbrake but your TV settings (or whatever media player you are using)."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Any way to keep smooth mpeg2 playback with Handbrake?
By Forty0zFreedom in forum Newbie / General discussionsReplies: 11Last Post: 26th Apr 2012, 16:58 -
Handbrake playback codec?
By jfharper in forum Video ConversionReplies: 2Last Post: 8th Nov 2011, 20:52 -
Handbrake, tsMuxeR, sound issues
By Johnnyp in forum Blu-ray RippingReplies: 3Last Post: 10th Nov 2010, 13:06 -
DVD vob to AVI using Handbrake and lip sync issues viewing on PS3?
By GolfGTdude in forum Video ConversionReplies: 0Last Post: 13th Sep 2010, 15:53 -
Getting Audio sync issues with handbrake suddenly...
By nodollas in forum Video ConversionReplies: 4Last Post: 30th Jan 2010, 06:44
