Results 1 to 12 of 12
    Sep 2006
    I have downloaded a few videos from twitch.tv. When I attempt to play the files in MPC-HC or VLC there is no audio. I have installed FLVsplitter and Xiph.Org Open Codecs with no success. Attached is the mediainfo information.
    General
    Complete name                            : K:\downloads\House of Sim Summer Stream! - Part 1.flv
    Format                                   : Flash Video
    File size                                : 161 MiB
    Duration                                 : 2h 0mn
    Overall bit rate                         : 188 Kbps
    Tagged date                              : UTC 2012-08-14 00:50:18
    Tagging application                      : flvmeta 1.1-r213
    jtv_meta                                 : eyJvcmlnaW4iOiA2Mjk4NDAsICJmaWxlIjogImh0dHA6Ly92aWRlbzExMS0xOjQ1NTcvY29udGVudC9saXZlX3VzZXJfaG91c2VvZnNpbV8xMzQ0ODk4MjAxLmZsdiIsICJicm9hZGNhc3RfcGFydCI6IDEsICJmZWF0dXJlZCI6IGZhbHNlLCAiY2hhbm5lbF9zdWJzY3JpcHRpb24iOiBmYWxzZSwgIm1ldGFkYXRhX2ZpbGUiOiAiaHR0cDovL05vbmU6NDU1Ny9qc29uL2xpdmVfdXNlcl9ob3VzZW9mc2ltXzEzNDQ4OTgyMDEuZmx2Lmpzb24iLCAiY2RuX3ByZWZlcnJlZCI6IGZhbHNlLCAicmVhZHkiOiBmYWxzZSwgInBhcnRuZXIiOiBmYWxzZSwgImlkIjogMzYwNzUzMTIzMiwgImNhdGVnb3J5IjogImdhbWluZyIsICJzZXJ2ZXJfbmFtZSI6ICJ2aWRlbzExMS0xIiwgInRpdGxlIjogIkhvdXNlIG9mIFNpbSBTdW1tZXIgU3RyZWFtISIsICJpbnN0YW50X3JlcGxpY2F0ZSI6IGZhbHNlLCAicmVjb3JkZXIiOiA2Mjk4NDAsICJlbWJlZF9lbmFibGVkIjogdHJ1ZSwgImNoYW5uZWwiOiAiaG91c2VvZnNpbSIsICJ1cF90aW1lIjogMTM0NDg5ODIwMSwgImZvcm1hdCI6ICJsaXZlIiwgInN0YXJ0X3RpbWUiOiAxMzQ0ODk4MjAxLCAiYWJ1c2VfcmVwb3J0ZWQiOiBmYWxzZSwgImlwaG9uZV9yZXN0cmljdGVkIjogZmFsc2UsICJwYXJ0IjogMSwgImRpcmVjdG9yeV9oaWRkZW4iOiBmYWxzZSwgImdlbyI6ICJVUyIsICJraWxsZWQiOiBmYWxzZSwgInVuZmluZGFibGUiOiBmYWxzZSwgIm5hbWUiOiAibGl2ZV91c2VyX2hvdXNlb2ZzaW0iLCAibGFuZ3VhZ2UiOiAiZW4iLCAidHlwZSI6ICJhdXRob3JpemF0aW9uIiwgImNoYW5uZWxfaWQiOiAzMjgzNDc0NCwgImJyb2FkY2FzdGVyIjogImZtZSIsICJkZWxheV9sZW5ndGgiOiAwLCAidXBkYXRlZF9vbiI6IDEzNDQ4OTgyMDEsICJtZXRhZGF0YV9zZXJ2ZXIiOiBudWxsLCAiY2hhbm5lbF92aWV3X2NvdW50IjogMTY0MX0=
    Video
    Format profile                           : High@L5.1
    Format settings, ReFrames                : 4 frames
    Codec ID                                 : 7
    Duration                                 : 2h 0mn
    Bit rate                                 : 147 Kbps
    Width                                    : 854 pixels
    Height                                   : 480 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 24.944 fps
    Bits/(Pixel*Frame)                       : 0.014
    Stream size                              : 131 MiB (81%)
    Writing library                          : x264 core 120 r2164 da19765
    Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=30.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=1000 / vbv_bufsize=1000 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format                                   : Speex
    Codec ID                                 : 11
    Duration                                 : 2h 0mn
    Bit rate                                 : 27.3 Kbps
    Channel(s)                               : 1 channel
    Sampling rate                            : 11.025 KHz
    Bit depth                                : 16 bits
    Stream size                              : 28.2 MiB (17%)
  2. ffplay should be able to play it
    (if you download one the builds from zeranoe, you will see speex is one of the external libraries used , so the ffplay that comes with ffmpeg should be able to play it)
    http://ffmpeg.zeranoe.com/builds/
    It's not a common audio compression, so common or popular media players probably wouldn't have compiled support for it
    Sep 2006
    Thanks worked great. Saved me the effort of transcoding.
  4. DECEASED
    Jun 2009
    Heaven
    Just for the notes,
    Mplayer is much better than ffplay
    Also, there is a Speex ACM decoder which can be used by DirectShow players like MPC-HC
    ( BUT I have not checked if it works with any FLV splitter )
    Sep 2006
    Mplayer gave me the following error.
    MPlayer Redxii-SVN-r34992-4.6.2 (C) 2000-2012 MPlayer Team
    192 audio & 400 video codecs
    Playing K:\downloads\House of Sim Summer Stream! - Part 1.flv.
    libavformat version 54.6.101 (internal)
    libavformat file format detected.
    [lavf] stream 0: video (h264), -vid 0
    [lavf] stream 1: audio (unknown), -aid 0
    VIDEO:  [H264]  854x480  0bpp  25.000 fps    0.0 kbps ( 0.0 kbyte/s)
    Load subtitles in K:\downloads\
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    libavcodec version 54.25.100 (internal)
    Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
    Requested audio codec family [speex] (afm=speex) not available.
    Enable it at compilation.
    Cannot find codec for audio format 0x20787073.
    Audio: no sound
    Starting playback...
    Unsupported PixelFormat 61
    Unsupported PixelFormat 53
    Unsupported PixelFormat 81
    Movie-Aspect is undefined - no prescaling applied.
    VO: [directx] 854x480 => 854x480 Planar YV12
    V:   3.6   0/  0 15% 10%  0.0% 0 0
    Exiting... (Quit)
    K:\mplayer-svn-34992\mplayer-svn-34992>
  6. Member bat999's Avatar
    Feb 2008
    Audio: no sound
    Hi
    Your version of mPlayer has been compiled without speex support.
    Maybe you can find a different version.
    Mine is OK because I compiled it myself with Linux.
    @ubuntu:~$ mplayer testfile.flv
    MPlayer SVN-r35084-4.5.2 (C) 2000-2012 MPlayer Team
    Playing testfile.flv.
    libavformat version 54.23.100 (internal)
    VIDEO:  [H264]  512x288  0bpp  15.000 fps    0.0 kbps ( 0.0 kbyte/s)
    Clip info:
     encoder: Lavf54.23.100
    Load subtitles in ./
    libavcodec version 54.52.100 (internal)
    Opening audio decoder: [speex] Speex audio decoder
    Invalid or missing extradata! Assuming defaults.
    AUDIO: 16000 Hz, 1 ch, s16le, 27.8 kbit/10.86% (ratio: 3475->32000)
    Selected audio codec: [speex] afm: speex (Speex audio)
    [AO OSS] audio_setup: Can't open audio device /dev/dsp: No such file or directory
    AO: [alsa] 16000Hz 1ch s16le (2 bytes per sample)
    VO: [x11] 512x288 => 512x288 Planar YV12
    [swscaler @ 0xb7750500]using unscaled yuv420p -> bgra special converter
    A:   2.9 V:   2.9 A-V: -0.000 ct: -0.007   0/  0 12%  9%  0.7% 2 0
    Exiting... (Quit)
  7. DECEASED
    Jun 2009
    Heaven
    Of course, you need a build that is not b0rked...
    [D:\DVD-7]
    =>mplayer tttspeex.avi
    MPlayer Sherpya-SVN-r34401-4.6.2 (C) 2000-2011 MPlayer Team
    181 audio & 389 video codecs
    Fontconfig warning: no <cachedir> elements found. Check configuration.
    Fontconfig warning: adding <cachedir>WINDOWSTEMPDIR_FONTCONFIG_CACHE</cachedir>
    Fontconfig warning: adding <cachedir>~/.fontconfig</cachedir>
    Fontconfig error: out of memory
    Playing tttspeex.avi.
    AVI file format detected.
    [aviheader] Video stream found, -vid 0
    [aviheader] Audio stream found, -aid 1
    VIDEO:  [WMV3]  576x288  24bpp  30.000 fps   50.8 kbps ( 6.2 kbyte/s)
    Opening video decoder: [dmo] DMO video codecs
    DMO dll supports VO Optimizations 0 1
    DMO dll might use previous sample when requested
    Decoder supports the following formats: YV12 YUY2 UYVY YVYU RGB8 RGB555 RGB565 RGB24 RGB32
    Decoder is capable of YUV output (flags 0x1b)
    VO: [directx] 576x288 => 576x288 Planar YV12
    Selected video codec: [wmv9dmo] vfm: dmo (Windows Media Video 9 DMO)
    notification: This doesn't look like a Speex file
    AUDIO: 32000 Hz, 2 ch, s16le, 44.9 kbit/4.38% (ratio: 5610->128000)
    AO: [dsound] 32000Hz 2ch s16le (2 bytes per sample)
    notification: Packet is larger than allocated buffer
    Exiting... (Quit)
    [D:\DVD-7]
    Sep 2006
    Yep switching versions fixed the problem. The version I downloaded from videohelp was the problem. The version from this site worked fine though http://sourceforge.net/projects/mplayer-win32/
  9. Banned
    Freedonia
    At that bit rate and sampling rate that audio is going to sound like crap! Never heard of speex before but I found some info on it. I don't know what twitch.tv is, but I can tell you that based on your audio alone I'd probably never watch it. You should be aware that the video is rather bizarre too. I would basically expect this file to never play on any standalone media player I've heard of.
    Sep 2006
    The audio is only speech so very low bitrates required. As for the wierd video what do you expect from a streaming video site.
  11. Member bat999's Avatar
    Feb 2008
    ... switching versions fixed the problem.
    That's good.
    Now you could install SMPlayer...
    And replace the mplayer.exe with your new version.
    C:\Program Files/SMPlayer/mplayer/mplayer.exe
    From here ---> http://smplayer.sourceforge.net/index.php?tr_lang=en
    Sep 2006
    I did that as soon as mplayer stated working on its own.
