I've done quite a bit of reading on CPU vs GPU encoding, finding that software and quality are the main issues with GPU. My question is with programs such as avitodvd, dvd flick, devede, or others (paid or not) will on board graphics vs dedicated GPU make ANY difference on medium to high level CPU systems in terms of converting times or quality?
Anything that will make a difference? input vs output on different drives? Use a SSD for one of them? Right now I can run more than one program at a time without maxing out the cpu, just looking for a way to make things eaiser.
Ssd won't help encoding at all unless you can encode at 500 Mb a sec,the only other thing that will make a difference is cpu power and its efficiency.
This can make a measurable difference depending on the speed of the drives, especially if one or both drives are badly fragmented. If the software you're using to encode is multi-threaded and you're not maxing out your CPU on a regular basis when encoding then that does suggest that there's probably an I/O bottleneck coming into play.
Of course, the other option is to avoid wasting those unused CPU clock cycles by bringing up the encoder quality settings to keep the CPU busier and use them up. If you get the balance right you'll still be encoding at approximately the same speed but have better looking encodes 'for free'.
Seeking advice on video playback from a PC, software/hardware capabilities
By wbjeeper in forum Software PlayingReplies: 7Last Post: 8th Dec 2010, 16:35 -
SSA/ASS capabilities
By tekkyyy in forum SubtitleReplies: 2Last Post: 12th May 2009, 06:31 -
DVD-R capabilities
By Navajas in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 13:58 -
TBC capabilities of DV2001
By BigMick in forum Capturing and VCRReplies: 0Last Post: 20th Dec 2007, 07:09 -
Adobe Premiere Capabilities
By jwfc in forum Newbie / General discussionsReplies: 2Last Post: 22nd Oct 2007, 17:18
