I am currently running on Mountain Lion using a iMac and was wondering how to split a MP4 by size? I ilke the feature on tsMuxer where you can split by gb although I am not looking to mux my mp4 only split it. I want to split a 9 GB file in 3 3gb parts. I have been trying to find freeware but had no luck. If anyone knows of a program or method of doing this it would be much appreciated. Thanks
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 10 of 10
In the future, if you ask ANYTHING at all that is specific to a Mac, it needs to go in our Mac forum. If you're doing it on a Mac, it's a Mac question. Posts in our Mac forum show up with a special symbol on the main page and we have a small number of Mac users who specifically look for posts with that symbol to see if they can help.
Since tsmuxer works on Macs, I don't understand why you can't use it. You said it "can split by gb" so I don't understand why you can't use it since your own post says it will do what you want. The truth is that all the good freeware is on Windows. I'm writing this on an iMac right now but it's still the truth. Windows has the tools. Mac doesn't. Surely if for some reason tsmuxer cannot do this then there must be some kind of Mac video editor you can use. Perhaps iMovie can do it. -
I only wanted to split not convert the file. If I put it into tsMuxer and set the settings up to split. It is going to change it from MP4 to ts or m2ts. I do not want to do this. I want to split my mp4 by size into 3 parts and have it remain in .mp4 format. Plus for some reason when I put it into tsmuxer it doesnt even load right. But that is not the issue because I dont want the final file in a transport stream I want to keep it a mp4. Thanks
Thread moved to the mac forum.
mp4box -splits 3145728 inputfile.mp4
Get a Pre-Compiled MP4Box here. Move the binary to e.g. /usr/local/bin for easy access, so that Terminal knows where to look for it.Last edited by Case; 15th Aug 2012 at 00:24.
Case: Nice info. I've DL'd the app and filed your message where I can find it. Very helpful.
Your request spurred me into creating the app you asked for. Download it here:
HTML Code:http://fs07n3.sendspace.com/dl/df5752c65eec0701e44b99c992f7083e/502c1866728a541c/lq97xw/MP4ToolboxGUI-OSX.app.zip
The app assumes you've downloaded and installed the pre-compiled MP4box app per Case's recommendation (inside /usr/local/bin ). My app can run from anywhere. No; it's not signed so, if you have 10.8 set to only trust signed apps and App Store apps, you'll need to depress the Control key when you click on the app and select Open.
There's very little error checking in the app at this point. When it asks you to select your MP4 file you can select anything. Be careful. I did add a field where the text output from the shell command is placed so, if something isn't working well for you, copy and paste that text into a message to me and I'll try to fix things.
I'll do some decent documentation soon enough. Thanks for your patience.
Splitting MP4
By rocks911 in forum EditingReplies: 1Last Post: 1st Mar 2012, 23:11 -
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 19:46 -
Problems splitting MP4 with Yamb
By trokua in forum Video ConversionReplies: 0Last Post: 3rd Aug 2010, 22:10 -
Converting to PS3 .mp4 with MP4 Converter on Mac
By The Sumerian in forum MacReplies: 2Last Post: 29th Dec 2008, 21:24
