Just got a dct6200 and read a few older posts about doing firewire capture and was wondering if it can still be done with this older model or if shaw here in vancouver island disabled it or added encryption.
If it still can be done i'll buy a firewire card and give it a try.
	I think you may know this, but I want to mention it anyway as someone may find this thread later via an Internet search and look at it.
 No 64 bit version of Windows is able to do this type of firewire capture. 32 bit versions through Windows 7 do work. If you have a Linux server then it should work and Apple is also supported out of the box, although you may wish to find and install the FireRecord program to do your captures under Apple.
 I am sorry but I do not know if this specific model used by Shaw works. You're probably just going to have to try. You should probably do that anyway as even if they do usually disable the ports, there's always a chance that a specific unit may not have that done due to oversight.
	Ya,i read about no firewire capture drivers for 64 bit,ill give it a try in win7 32 to see if if the firewire still works. I think,therefore i am a hamster.
  Motorola DCT6214 PVR to DVD-R via firewireBy kenmo in forum DVD & Blu-ray RecordersReplies: 8Last Post: 2nd Jun 2009, 13:04
  Problems creating DVD from Shaw Cable Motorola DCT64616 III transport streaBy Mendel in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 7th Feb 2008, 10:45
  transferring video from cable Motorola dvrs to pc?By Dr.Gee in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2008, 15:23
  Capturing HD from Motorola 6412 via firewireBy z0diac in forum DVB / IPTVReplies: 1Last Post: 16th Jan 2008, 09:35
  HDTV Cable Card from motorolaBy lein in forum DVB / IPTVReplies: 4Last Post: 4th Oct 2007, 16:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
