which software can i use to extract subtitles as .srt file from any format video?![]()
Sounds like you are looking for a "universal solvent." The extraction tool has to know about the container in question. Also if the subs are in a graphical format you may have to extract them and do OCR. There is no "one size fits all" tool. That's why you have a software toolbox. Not just one pair of pliers.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
The only universal method for "any format" is to type them in yourself.
Otherwise you have to work out what kind of subtitles are in the file and then use the appropriate way to extract them. -
i think mkvtoolnix is used to extract subtitles from mkv files.
but how to extract it?
tell me the procedure.
Subtitle Edit can extract subtitles from mkv / mp4 / dvd / divx + reads more than 100 subtitle formats!
But that still leaves hardcoded subtitles, ts files, and probably a few more
Does anyone know how to extract subtitles from .ts?
By ALUOp in forum DVB / IPTVReplies: 48Last Post: 27th Jul 2022, 01:39 -
How to extract subtitles from .wtv?
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 12th Jan 2012, 21:44 -
Extract subtitles from .ts
By anchonio in forum DVB / IPTVReplies: 9Last Post: 16th Apr 2011, 05:07 -
convert from ezonics Live Express .exe to some other video format, extract
By johnyb1 in forum Video ConversionReplies: 3Last Post: 14th Jul 2009, 23:07 -
Can't extract DVD subtitles
By idrougge in forum ffmpegX general discussionReplies: 1Last Post: 21st Nov 2008, 14:58
