Results 1 to 15 of 15
  1. I had to remove Adobe Flash, and now RTMP won't work on sites as CBS.com, which tells me I need to install Flash 9.0. I have the latest version of flash installed, shouldn't it work this is frustrating.
    Oct 2010
    England
    You'll get better advice if you say what browser (+version) you're using.
    Are you using any other browser plugins; ad blocking, etc?
    It seems odd that you're only having problems with RTMP streams... AIUI, youtube doesn't stream videos using RTMP - so do YT vids play ok?
  3. Originally Posted by intracube View Post
    I can load the site in FireFox 15 (Beta 2), but RTMP CBS.com just gives me a error that I need to install Flash 9.
    Oct 2010
    England
    What do you mean by "RTMP CBS.com"?
    Do you mean a program like RTMPDump or similar?
  5. Originally Posted by intracube View Post
    RTMP Explorer.
    For the longest time, I had no problems with RTMP Explorer and downloading video from CBS.com, because I had to remove Flash, I'm having problems downloading videos from that site, arggh.
    Oct 2010
    England
    I haven't used that program so someone else will have to give some specific suggestions.
    Maybe the version of RTMP Explorer has been designed to work with a particular version of Flash. You could try downloading the latest version of the program and see if it supports Flash 10.
  7. Originally Posted by intracube View Post
    I'm using the latest version of RTMP Explorer, argh.
  8. Stream recording expert Bahman's Avatar
    Dec 2011
    Tehran, Iran
    PowerFalcon, RTMPExplorer uses IE for browsing webpages! if you have removed adobe flash plugin of IE, its no problem! but keep adobe flash plugin of FireFox! Then you can use FireFox with RTMPdump helper and download rtmp streams!
  9. It is working once again
  10. Dear Forum (especially member Bahman, seems you're quite into this streaming stuff )
    The guys over at CBS.com definitely changed something in the backend because since a few days I'm
    not able to capture TV Shows anymore (with applian Replay Media Catcher).
    Can you please confirm that 'RTMPExplorer' works on CBS as of today? This would be very helpful ...
    Best regards
  11. Stream recording expert Bahman's Avatar
    Dec 2011
    Tehran, Iran
    Hey there,
    I tried 60 min show and this is the result:
    RTMP Server
    (c) 2010 Andrej Stepanchuk, Howard Chu; license: GPL
    Streaming on rtmp://0.0.0.0:1935
    rtmpdump -r "rtmpe://cp48590.edgefcs.net:1935/ondemand" -a "ondemand?ovpfv=1.1&?
    auth=daEbCdectccajdia5bmdsaydVbMcbctcUal-bqmu8o-h0-McAOlWld&aifp=v001&sl
    ist=video%2Ftemp_hd_gallery_video%2FCBS_Production%2FCBS_Production_News%2F2012%
    2F03%2F01%2F60_Minutes%2F60_Minutes_Previews%2F55%2F133%2F" -f "WIN 11,3,300,271
    " -W "http://vidtech.cbsinteractive.com/player/3_0_1/CBSI_PLAYER.swf" -p "http:/
    /www.cbs.com/" -C Z: -y "mp4:video/temp_hd_gallery_video/CBS_Production/CBS_Prod
    uction_News/2012/03/01/60_Minutes/60_Minutes_Previews/55/133/60_archbishop__9740
    71.mp4??auth=daEbCdectccajdia5bmdsaydVbMcbctcUal-bqmu8o-h0-McAOlWld&aifp=v00
    1&slist=video%2Ftemp_hd_gallery_video%2FCBS_Production%2FCBS_Production_News
    %2F2012%2F03%2F01%2F60_Minutes%2F60_Minutes_Previews%2F55%2F133%2F" -o 60_archbi
    shop__974071.flv
    Closing connection... done!
    RTMPDump v2.4
    (c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL
    Connecting ...
    WARNING: HandShake: Type mismatch: client sent 6, server answered 9
    INFO: Connected...
    Starting download at: 0.000 kB
    INFO: Metadata:
    INFO:   duration                74.17
    INFO:   moovPosition            28.00
    INFO:   width                   640.00
    INFO:   height                  360.00
    INFO:   videocodecid            avc1
    INFO:   audiocodecid            mp4a
    INFO:   avcprofile              100.00
    INFO:   avclevel                40.00
    INFO:   aacaot                  2.00
    INFO:   videoframerate          29.97
    INFO:   audiosamplerate         22050.00
    INFO:   audiochannels           2.00
    INFO: trackinfo:
    INFO:   length                  2222220.00
    INFO:   timescale               30000.00
    INFO:   language                eng
    INFO: sampledescription:
    INFO:   sampletype              avc1
    INFO:   length                  1635327.00
    INFO:   timescale               22050.00
    INFO:   language                eng
    INFO:   sampletype              mp4a
    387.419 kB / 4.20 sec (5.6%)
    What do you think then?
  12. thanks for the quick reply ...
    in the meantime, btw, i learned more:
    2 (different) RTMPDump win32 builds
    https://github.com/K-S-V/Scripts/downloads
    https://www.videohelp.com/download/rtmpdump-v2.4-35-ge0056c5-master.7z
    2 gui
    RTMPExplorer
    rtmpdumphelper (nir sofer)
    at the moment i cannot test the actual d/l but i want to capture episodes 'the bold and the beautiful'
    from the cbs.com site.
    it would be great if you could confirm one configuration under which one specific episode from
    'the bold and the beautiful' (let's say e.g the one from last thursday) can be completely captured
    (100% = approx. 20 minutes per episode).
    thanks
  13. Stream recording expert Bahman's Avatar
    Dec 2011
    Tehran, Iran
    They uses the same service for streaming this show too! So, there is no difference!
    Also, I recommend you to use this build: https://github.com/K-S-V/Scripts/downloads
  14. fyi:
    nir sofer tool + rtmpsuck (K-S-V build) + ie9 = does not work (rtmpsuck error message)
    nir sofer tool + rtmpsrv (K-S-V build) + ie9 = does not work (rtmpsrv error message)
    RTMPExplorer + rtmpsrv (K-S-V build) = works!
    Bahman, thanks for your testing.
  15. I have encountered another RTMP problem. When I try to download a show from CBS.com, I put the address of the video file into the address bar and explorer won't load the page I only get the error to 'refresh the page' ? I've tried numerous times, resetting the PC etc, it was working a few days ago. I even download RTMP explorer again, hoping a new download may fix something, even if minor, not the case
