After burning a movie my pc will not play it. Whatever player I try and use (vlc, wmp, mpclassic, etc) it pops up a window with the 'please insert a disk' message. These discs play fine on all the stand-alone players in our house, including our blu-ray player. However, the pc will play all my factory discs. Ideas?
-thnx.
Are you using WinME, as your computer details indicate? You might have burned the disc correctly, especially if you were using Imgburn, but your system may not have anything installed to allow you to read UDF format discs.
If cameras add ten pounds, why would people want to eat them? -
Thnx for replies -
I have updated my sys specs (sorry) :
Win 7 Home Premium 64-bit
Intel Pentium Dual Core E5300@2.60 GHz
RAM 6 GB
HDD 600 GB
... and I used ConvertXtoDVD 4 to create the Video_TS files and burn. As before, they work great on our stand-alones. -
What media are you using? Are other data discs created with the same media readable on the system?
(Is it possible to create an ISO or other disc image within ConvertX2DVD, with which you could experiment with test-burning it using Imgburn?)
Does the disc read properly in any other computer? (Just in case it may potentially be a CD/DVD/BD drive issue...)If cameras add ten pounds, why would people want to eat them? -
New project finished - issue remains.
Played disc on another computer and it works there.
Crap!
Went to Device Manager and uninstalled DVD.
Re-boot computer.
Disc works now!?!?
Man! Why does this happen?????????
Help with burned DVD's skipping
By BDrums1971 in forum Newbie / General discussionsReplies: 20Last Post: 1st Sep 2013, 16:06 -
i just burned a dvd?
By just in forum Newbie / General discussionsReplies: 1Last Post: 20th Nov 2008, 22:41 -
burned DVD can't be played
By linda.0p in forum DVD RippingReplies: 2Last Post: 19th Sep 2008, 14:18 -
Problems with burned DVD's
By iceman22 in forum Authoring (DVD)Replies: 4Last Post: 3rd Sep 2008, 20:00 -
no sound on a burned dvd
By kissy in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2008, 19:38
