I can extract audio from a avi movie and use audacity to make it louder the extracted audio is .wav. but how do I join the wav sound back again to the avi movie after I have enhanced it
other options:
you can use audacity to encode to the final audio format as well (or leave it as wav), then use avi-mux gui to "join" it back together
or vdub audio=>audio from other file (video and audio direct stream copy mode) , or vdub can encode audio as well -
thanks for reply but when I extract audio from movie which is .wav but when i looad this .wav audio into audacity and press play its all jubbled up. how do i fix that and make audio louder and what format do i save it as
what do i set the audio settings as.AviDemux is what I use for doing exactly that....with MPEG2 files. Should work the same with other stuff. Just make sure you set the video settings to "COPY".....then adjust the audio settings accordingly. -
What format is the original audio in? I guess it'd be MP3 or AC3?
If it's MP3 I'd open the AVI with VirtualDubMod, select Streams/Streams List from the top menu, then select Demux and save the MP3 audio to your hard drive. The same process can be used for AC3, or VirtualDubMod will save the audio as a wave file.
If it's MP3, open the extracted audio using MP3DirectCut and use it's normalise function to normalise the MP3, then resave it as a new file. No re-encoding required. Once that's done, use VirtualDubMod to replace the old audio with the new version (if you've extracted the audio with VirtualDubMod, working out how to disable the old and add the new audio to the AVI shouldn't be too hard) and resave it as a new AVI, selecting "Direct Stream Copy" for the video while saving.
If it's AC3, once it's extracted you'll have to convert it while changing it's volume.
how to enhance audio in an mp4 / avi video file
By antinikhil in forum Video ConversionReplies: 6Last Post: 15th Jul 2012, 01:00 -
Video enhance
By Videographer in forum Newbie / General discussionsReplies: 0Last Post: 28th Aug 2011, 16:10 -
can someone help me enhance mpeg audio?
By chasingtime in forum RestorationReplies: 8Last Post: 18th Nov 2010, 12:53 -
is it possible to enhance audio?
By deadrats in forum AudioReplies: 2Last Post: 9th Jan 2010, 19:46 -
How to enhance custom animations?
By wan2no in forum Newbie / General discussionsReplies: 5Last Post: 4th Apr 2008, 22:13
