I've got some footage in 720x480 NTSC DV 4:3, pixel aspect ratio 0.9091.
I need to get that to a square pixel output to show on a computer screen.
What square pixel project settings do I need to have this look good?
(I am using Sony Vegas)
Or just resize the entire 720x480 frame to 640x480 (or any 4:3 frame size ratio you want). By the spec, the full 720x480 frame contains the 4:3 image. But many DVDs, especially those recorded from analog video tape, use the inner 704x480 because that is the spec for ITU D1 analog to digital conversion. Nobody in the industry seems to care about the difference. In any case, the difference isn't visible unless you break out a ruler and measure the picture. The deciding factor may be if there are ~8 pixel black borders at the left and right edges of the frame.
It's DV AVI, though, and not a DVD. It's most likely from an analog source, I would guess, and that's why I didn't qualify my response. I also agree that even just resizing the whole thing to some 1.33:1 ratio (if it doesn't have any black bars, for example) won't make a lot of difference because most likely no one will be able to tell the difference anyway.
But you don't change the project settings in vegas. They should match the footage, ie. NTSC 720x480 , lower field first, PAR 0.9091 .
What you do change are the render settings to 640x480 plus whatever format you are using.
If you render to a progressive format, vegas will deinterlace depending on what you have set in the project settings (i.e. if it's set to blend, it will blend; if it's set to interpolate, it will interpolate) . Neither is very good (vegas doesn't do a good job of deinterlacing), but most people leave it set to interpolate if they use vegas to deinterlace -
Can you provide more information on the other mixtures of footage? use mediainfo (view=>text) if you don't know
You usually set the project properties to the dominant footage (whatever you use the most of)
All different spec footage will be conformed to those timeline settings (project properties)
What are your end goals (is it only a 640x480p29.97 or 59.94p?) progressive export? or multiple exports like DVD-video plus something else ? -
conversion square to non square pixels???
By jakeotr in forum Video ConversionReplies: 7Last Post: 27th Jan 2012, 01:53 -
Square pixels, NTSC .912, Anamorphic 1.215 when processing in Virtualdub?
By brassplyer in forum EditingReplies: 3Last Post: 21st Jan 2011, 07:24 -
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 03:56 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 11:20 -
should use square pixels or not for 16:9?
By j.man in forum Video ConversionReplies: 5Last Post: 4th Mar 2008, 22:28
