Closed Thread
Results 1 to 30 of 49
    Nov 2006
    Australia
    Hi guys.
    I have a VOB file that is 16:9 but should be 4:3. So I used DVD Patcher to convert it to 4:3.
    When I play the VOB in VLC, WMP, MPC it is still 16:9.
    When I play the VOB in Winamp it is 4:3.
    If I open the VOB in DVD Patcher again it says it is 4:3.
    MediaInfo still says it is 16:9.
    A Kind of Magic (2).vob
    Format                                   : MPEG-PS
    File size                                : 299 MiB
    Duration                                 : 4mn 40s
    Overall bit rate                         : 8 930 Kbps
    Video
    Format                                   : MPEG Video
    Format version                           : Version 2
    Format profile                           : Main@Main
    Format settings, BVOP                    : Yes
    Format settings, Matrix                  : Default
    Duration                                 : 4mn 40s
    Bit rate                                 : 5 500 Kbps
    Width                                    : 720 pixels
    Height                                   : 480 pixels
    Frame rate                               : 29.970 fps
    Standard                                 : NTSC
    Scan type                                : Interlaced
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 0.531
    Stream size                              : 184 MiB (62%)
    Color primaries                          : SMPTE 170M
    Transfer characteristics                 : SMPTE 170M
    Matrix coefficients                      : SMPTE 170M
    Audio #1
    ID                                       : 189 (0xBD)-130 (0x82)
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    Mode extension                           : CM (complete main)
    Format settings, Endianness              : Big
    Muxing mode                              : DVD-Video
    Duration                                 : 4mn 40s
    Bit rate mode                            : Constant
    Bit rate                                 : 192 Kbps
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 16 bits
    Stream size                              : 6.42 MiB (2%)
    Audio #2
    ID                                       : 189 (0xBD)-137 (0x89)
    Format                                   : DTS
    Format/Info                              : Digital Theater Systems
    Format profile                           : 96/24 / Core
    Duration                                 : 4mn 40s
    Bit rate                                 : 1 510 Kbps
    Channel(s)                               : 6 channels
    Channel positions                        : Front: L C R, Side: L R, LFE
    Sampling rate                            : 96.0 KHz / 48.0 KHz
    Bit depth                                : 24 bits
    Stream size                              : 50.5 MiB (17%)
    Audio #3
    ID                                       : 189 (0xBD)-160 (0xA0)
    Format                                   : PCM
    Format settings, Sign                    : Signed
    Duration                                 : 4mn 40s
    Bit rate                                 : 1 536 Kbps
    Bit depth                                : 16 bits
    Stream size                              : 51.4 MiB (17%)
    Menu
    May 2009
    I have seen the same result a few times in the past if I selected 'First Header Only' in the Patch selection area. Usually worked properly if 'Entire File' was selected.
  3. you can try restream as well , but I think it only takes elementary video (you would have to demux and remux or reauthor)
    Nov 2006
    Australia
    Thanx for the replies.
    I definitely selected "Entire File".
    What is "elementary video"?
    I opened the VOB in restream & it detected it as 4:3.
  5. Originally Posted by skywalka View Post
    If ReStream says it's 4:3 then it is. That tells me that maybe you've messed with the AR playback for some of your players and have them set to play back as 16:9 when they should be set for 'source' or 'original' or 'default' or something like that.
    I don't know why MediaInfo might still say it's 16:9. This is a single VOB you're talking about, right? And not a DVD with the additional IFO and BUP files?
    Elementary video means the video alone (without the audio). If you want to separate the two, one way is to open the VOB in DGIndex and then File->Save Project and Demux Video.
    Nov 2006
    Australia
    Checked the AR settings & they are set to "Default" etc.
    It's a single VOB. At the beginning of the clip cover art is displayed then fades to black. I'd assumed this was just normal DVD video. Maybe it's not?
    Thanks for clarifying "elementary video".
  7. Member DB83's Avatar
    Jul 2007
    If this VOB has been ripped from the dvd "Queen The DVD Collection Greatest Hits 2", the correct AR is 16:9
    I own this DVD and just played the clip and can confirm it plays as 16:9
    If you think it should be 4:3 then I would imagine you are looking at an anamorphic 4:3 frame.
  8. Thanks, DB83, for identifying the DVD. And you're right, with some possible exceptions. This review of the R4 Australian DVD does say it's 16:9, but also points out some encoding errors on some of the songs:
    http://www.michaeldvd.com.au/Reviews/Reviews.asp?ID=3785
    skywalka's VOB is of the song 'A Kind Of Magic', one which was supposed to have been 4:3.
  9. Member DB83's Avatar
    Jul 2007
    I would concur. The picture looks a little 'flat'. A bit like you get if you merely stretch a 4:3 frame to fill a 16:9 one.
    From the back of the box (This is the UK release but I would have thought that all would come from the same master) - "All videos on Disk One (these are the main promos) are restored and shown as 16:9 widescreen......
    But, surely, you can not simply change an AR flag to correct this. The video would have to be re-authored.
  10. The author of the review mentions it's a problem for both the R4 and the R2 DVDs. And yes, changing the DAR flag for a VOB extracted from the DVD should fix the problem. It wasn't properly prepared to be encoded as 16:9 which, for an original 1.33:1 source, would have meant cropping from the top and bottom as was done for some of the others in the collection.
    I don't know why DVD Patcher couldn't fix it so all his players would play it correctly. I don't use DVD Patcher for this kind of thing, but would recommend (as did pdr) demuxing, fixing the DAR in ReStream, and then remuxing with Muxman. Except ReStream already says it's 4:3, so maybe demuxing/remuxing will be enough to fix it.
    Nov 2006
    Australia
    Yes that is the DVD I extracted the VOB from. If you change the aspect ratio in your player to 4:3 you will see that the clip then looks correct. The music video is also an extra on the Highlander DVD where it is shown at the correct AR but with black bars on the sides (I think the term is non-anamorphic).
    I've never muxed anything. Do you recommended Muxman to demux too?
    There are 3 audio tracks (commentary etc). Will that be a problem? While I'm on the topic, the commentary is the track being played by all the players as default. Is there a way to change that?
  12. Member DB83's Avatar
    Jul 2007
    This is an odd-ball.
    I took a little time out and ripped the vob from my dvd. The disk is PAL 25fps all region. I noticed that the OP's vob is NTSC.
    When I ripped the vob, mediainfo reports an AR of 2.40:1. I play this on a 4:3 monitor and borders are much wider than 16:9. If I play the VOB through vlc and change the AR to 4:3 it looks much more normal.
    So I then ran dvd-patcher and patched the entire vob to 4:3. It now plays back in vlc at default AR and looks much better. Mediainfo now reports the patched file at 16:9 - rememebr it did say 2.40:1 - try and figure that one out (there are still slight borders). I made a copy of the vob before I patched it so I can post the two reports if you want to see them.
    Nov 2006
    Australia
    Did your rip contain the coverart before the music video?
  14. Member DB83's Avatar
    Jul 2007
    Yes.
  15. Originally Posted by skywalka View Post
    No, Muxman only muxes. I already explained earlier one way to demux (by using DGIndex).
    No, when being remuxed just add in the audio tracks one-by-one.
    No, not when it's being played as a VOB. If you were to play it as a little 'mini-DVD' then you could choose the audio track, just as with any DVD (and the first track will be the default one).
    Muxman will create a DVD for you. You can choose to toss out the accompanying IFO and BUP files and just keep the VOB, or not.
    By the way, you can also do a proper conversion of the song to 16:9 and then add it back to the DVD. This means either cropping the top and bottom or adding black to the sides before then resizing and reencoding it as 16:9.
    Thanks again. That's the first time I've noticed that. The reason I chose the review of the R4 DVD is because skywalka is in Australia and I figured that's the one he'd have.
    Nov 2006
    Australia
    I was curious so I used DGIndex to get a demuxed m2v. Got this error message:
    Too many pictures per GOP (>= 500).
    DGIndex will terminate.
    But the resultant partial m2v (2m:14s) behaved the same as the VOB in the players.
    ReStream detected the m2v as 4:3 though only Winamp played it at this AR. I converted it to 16:9 to see what would happen & it simply squashed the picture vertically even more. However if I try & convert the original demuxed file to 4:3 there is no horizontal squashing.
    If I convert the m2v I vertically squashed more to 4:3 the end result appears the same as the original demuxed file (so the squash is removed). Converting that again to 4:3 doesn't appear to change anything.
  17. All very strange. If you wouldn't mind uploading that VOB somewhere (Sendspace, MediaFire, etc.) I'm sure some of us wouldn't mind having a look at it.
  18. Member DB83's Avatar
    Jul 2007
    Yeah, I would like to see the original vob - before any patching muxing etc. - if only to compare with the one I have.
    Could I also ask what you used to rip the vob ? Just in case that program created issues of its own. I used dvd-decrypter.
    With all the confusion about AR, may I also remind you that the vob you have is NTSC 720*480. Any patching etc. will have to retain that even tho you are 'Down Under' in PAL-land. If you in-advertently patch etc to 720*576 the clip will look even more strange.
    Nov 2006
    Australia
    Sorry, I didn't make a copy of the file before I used DVDPatcher on it. I thought if there was a problem I could just change it back to 16:9.
    I'm uploading it now in case you still want to examine it but the going is slow.
    Thanks for the AR info. I'm aware of the different resolutions so won't put the wrong settings.
    Nov 2006
    Australia
    Link to the VOB:
    http://depositfiles.com/files/lt68ywg9u
    I used DVD Decrypter in IFO mode. I didn't realise until later that you can rip the clips without the coverart at the beginning.
  21. If you remove the sequence display extension in restream, it should play 4:3 in all players (if you were planning to just reflag it)
    But it has your typical PAL=>NTSC field blending as well . Another option would be to get rid of the blends (but would require re-encoding)
  22. Originally Posted by skywalka View Post
    This is bizarre. Normally DGIndex is very reliable and handles MPEG2 streams consistently . I'm wondering if your sample should be forwarded to the author
    Anyways, to demux this, you can use eac3to. It will demux everything, including captions, all 3 audio tracks
    It's a CLI app, but there are gui's for it (I don't know if they have all the options such as demux all tracks, and the gui's are rather cumbersome to set up)
    The syntax is eac3to input.ext -demux
  23. Originally Posted by poisondeathray View Post
    Yes, that is the problem. The sequence display extension says the 4:3 picture us contained in a 540x480 subsection of the frame. So the full 720x480 frame turns out to be 16:9. 720 / 540 * 1.333 = 1.778
  24. Originally Posted by jagabo View Post
    Yes, it's a good test to see which software players respect the sequence display extension
    (and if anyone else is wondering, the value can be found with gspot)
    Any idea why dgindex "barfs" on this stream ?
  25. DECEASED
    Jun 2009
    Heaven
    No idea, except that probably DGindex sucks at demuxing
    Just for the notes, I have used DGindex always and only for indexing elementary streams ---
    --- for demuxing, I prefer PGCdemux or TMPGEnc, depending on the case.
  26. Originally Posted by El Heggunte View Post
    If I've demuxed M2Vs using DGIndex once I've probably done it a couple of hundred times without incident - until now. And it's choking at the indexing, even after the sequence extension is removed.
    You can't demux using PGCDemux as this is only a VOB, and not a DVD. IFOEdit won't create IFOs for the VOB, saying there's something wrong with the VOB. After demuxing the VOB streams with HdBrStreamExtractor (a GUI for eac3to) and reauthoring with Muxman without incident, the new VOB still won't index using DGIndex. After demuxing that Muxman-created DVD using PGCDemux, the new M2V still won't index using DGIndex. I used FFMPEGSource on it in a script. There's something very peculiar about this video stream.
  27. I would have expected muxman to spit out errors if there was something wrong with it
    And videoredo's quickstream fix didn't detect any errors either
    eac3to did say there were issues with the authoring when demuxing, but didn't specify exactly what . (But "authoring faults" shouldn't apply to elementary stream when demuxed)
    [a03] This EVO/VOB file contains authoring faults. Will try to work around that. (2034) <WARNING>
    ProjectX said something about missing startcodes and dropping packets when processing the vob
    manono - would you please notify neuron2 about this? I wonder what he has to say
  28. Originally Posted by poisondeathray View Post
    I'd be happy to, and had thought about it already. Except for one thing. The file has already been run through DVDPatcher. Therefore it's not really the source VOB. I don't know enough about what it does to say with confidence it didn't do anything important to the VOB. I'd feel much more comfortable offering neuron2 a VOB straight from the DVD.
    But I'll ask him about it anyway.
  29. Member Cornucopia's Avatar
    This is where I also think mediainfo can be improved. Clearly (now) what it is doing is reading both the dar flag and the sequence display extension and combining them for the AR field display. That is not a bad thing, but it would help with troubleshooting if mediainfo actually TOLD us how/where it derives its values (hex locations, calculations, etc).
  30. Member
    Jan 2003
    India
    My version of DGIndex stops a little over halfway, saying it found GOP length more than 500. Loading in virtualdubmod, I find that it is using a GOP of 13 all through.
    My best guess is that the file is corrupt.
