Hi,
I got 2 exact movie...Which one do you guys think I better keep;
MOVIE A or MOVIE B?
Thanks in advance!
ps: please tell why you made the choise![]()
MOVIE A.
Video Stream
frame size, fps (ps per frame) 640*256, 29970 fps 33367ps
#of frames (time) 250546 2:19:19
decrompessor mpeg 4 fast motion
number of key frames 838
min/avg/max/total key frame size 807/9594/30788/ (7853k)
min/avg/max/total delta frame size 82/1720/36884 (419579k)
Audio Stream
sampling rate 48000hz
channels 2stereo
sample precision obit
compression fraunhofer IIS mpeg layer3 codec
preload skew 11192 samples (0.23s)
#of frames 250529
min/avg/max/total frame size 506/800/11192 195936k
MOVIE B.
Video Stream
720*336, 12.500 fps 80000ps
99737 2:12:58
mpeg 4 low motion
399
1523/13322/45828 (5197k)
121/4063/91188 (394158k)
Audio Stream
44100hz
2stereo
obit
fraunhofer IIS mpeg layer 3 codec
7981 samples (0.18s)
49863
16/2554/7981 (124373k)
Movie A because the Framerate is almost tripled in 29.97 opposed to 12
In Action scenes look at the difference and post your results. Why don't you combine the two (use 80 k/s in Movie A and keep the framerate)
Gloke
Whats beter than SD600?
By jupita in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 21st Jun 2011, 03:00
