hello ,
how to know about container of a video file ?
A container of a video file can be avi,mkv,mp4 etc..,what the container files have in them depends on the type,they can contain avc,divx,xvid codecs and subtitles and chapter files.To know about them use mediainfo.
here is mediainfo stats of my video file , where is container info ????
General
Unique ID : 241367632503871753142806481290873326839 (0xB595B71116C2B5B0AB637CFF5998CCF7)
Complete name : G:\telugu\Adhurs.2010.720p.BluRay.x264-TmG\Adhurs-720p-x264.mkv
Format : Matroska
Format version : Version 2
File size : 4.37 GiB
Duration : 2h 29mn
Overall bit rate : 4 176 Kbps
Encoded date : UTC 2010-07-17 04:22:59
Writing application : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul 3 2010 22:54:08
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 29mn
Bit rate : 3 423 Kbps
Width : 1 280 pixels
Height : 544 pixels
Display aspect ratio : 2.35:1
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.205
Stream size : 3.49 GiB (80%)
Title : Adhurs 720p @ TmG
Writing library : x264 core 100 r1659 57b2e56
Encoding settings : cabac=1 / ref=4 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3423 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : Telugu
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : ES
Muxing mode : Header stripping
Codec ID : A_DTS
Duration : 2h 29mn
Bit rate mode : Constant
Bit rate : 755 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 808 MiB (18%)
Title : Telugu DTS-ES
Language : Telugu
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English Subtitle
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:03:53.792 : en:00:03:53.792
00:06:02.000 : en:00:06:02.000
00:18:12.750 : en:00:18:12.750
00:27:21.375 : en:00:27:21.375
00:32:46.417 : en:00:32:46.417
00:44:47.708 : en:00:44:47.708
00:46:40.875 : en:00:46:40.875
00:53:41.833 : en:00:53:41.833
01:11:44.750 : en:01:11:44.750
01:18:40.917 : en:01:18:40.917
01:23:26.750 : en:01:23:26.750
01:29:02.458 : en:01:29:02.458
01:40:51.250 : en:01:40:51.250
01:47:19.667 : en:01:47:19.667
01:52:27.958 : en:01:52:27.958
02:01:47.750 : en:02:01:47.750
02:06:30.958 : en:02:06:30.958
02:17:24.292 : en:02:17:24.292
02:22:10.292 : en:02:22:10.292
02:27:40.542 : en:02:27:40.542 -
That info is always found in Mediainfo in the "General" category under the "Format" field. Note that the way it treats Quicktime and WMV and DivX containers may not be like you expect them: QT is considered by Mediainfo to be a subset of MP4 (not quite accurate), WMV is (accurately) described as ASF and DivX is (accurately) described as AVI.
[RANT]Personally, I wish this was made a little clearer to end users to end confusion or misinformation. QT is a sister format to MP4 (MP4 being a fork), WMV and ASF are the same thing (the extension being the only difference) so why not call it WindowsMedia/ASF?, and DivX could be labelled "DivX variant of AVI" or something (since it can support menus & chapters where normal AVI does NOT). There's a few more things about this app & Gspot that I wish was straightened out! [/RANT]
need to put content of FLV container into MP4 container
By arraboy in forum Newbie / General discussionsReplies: 3Last Post: 29th Jun 2012, 19:52 -
Have video container CBR or VBR ?
By n33 in forum Newbie / General discussionsReplies: 9Last Post: 14th Oct 2011, 05:03 -
How to Change Header(container) of Video
By king of swords in forum Video ConversionReplies: 2Last Post: 13th Jul 2011, 07:36 -
change an MKV container to AVI container???
By Spdngblt56 in forum Newbie / General discussionsReplies: 10Last Post: 17th May 2010, 21:23 -
How do you move files from .ogm container to .mkv container?
By VidHunter in forum MacReplies: 0Last Post: 8th Mar 2008, 18:19
