I have several parts recorded several times.
And there are problems I can not fix with ReplaceFramesMC .. Because the result is not good ..
So I try to copy frames from another recording that the problem does not occur with the copy, paste of VirtualDub.
But when I copy a frame and then paste it then nothing happens ..
VirtualDub does not paste the frame.
What to do?
I did a Google search and found a solution ..
So what was the solution?
In avisynth could use RemapFrames, RemapFramesSimple, RemapFramesSimple or ClipClop
http://avisynth.org/stickboy/
http://forum.doom9.org/showthread.php?t=162266
Or it's pretty easy to use a video editor with a timeline laid out and multiple tracks (e.g. Sony vegas, Premiere Pro) -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Replace about 50 frames of video in an .mpg file (keep audio the same)?
By gastrof in forum Newbie / General discussionsReplies: 6Last Post: 19th Jul 2011, 22:29 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 14:26 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
