Need a little help please. Ok the wonderful staff at Monoprice.com helped me choose which wires i needed. My pc is 43 FT away from my Samsung 2012 55 inch LED tv. I learned how to switch on the computer which monitor to use, but its a pain to monipulate since im so far away without seeing the tv. Question is, how would you guys deal with this situation. If i can find a wireless mouse/keboard that extends 50ft away, can i then use my tv as a monitor, i will be using it more on movies, i want to mount my iso movies and view on tv.Thanks all for the help. Hope i explained correctly.
I am surprised that you can even get a decent picture over a 43 ft cable run. You do not state what type of cables these are.
Your Samsung probably supports DLNA. If you only want to watch video that is on your PC then you can use a DNLA server such as Samsung's AllShare Media server, Serviio, Mezzmo, TVersity, XBMC, etc. With that technique you connect with WiFi or LAN Cable to your PC and select the video from your TV.
There are long range keyboards that work up to 100 ft but they are expensive. Do a Google search. -
Thanks i use now Samsungs Allshare, but Allshare does not support ISO dvd files, i have 500 dvd ISO files, the cables i use now that i tested last night were : 6ft mini-hdmi to hdmi cable going into an extender which extends 2 50ft cat6 wires, that goes into another extender which i add the cat6 cables to it, then i run it as hdmi-hdmi to the tv. I did a search on wireless keyboards, any good ones you can recommend. Again thanks all for the help.
Dvi from computer to hdmi to 65 inch panasonic plasma hd
By jplot in forum Newbie / General discussionsReplies: 1Last Post: 6th Mar 2011, 18:56 -
My 73 inch TV came in a 67 inch box. WTF?
By dafoe in forum Newbie / General discussionsReplies: 74Last Post: 20th Nov 2010, 22:22 -
viewing blu ray on computer
By sactown in forum Software PlayingReplies: 2Last Post: 16th Nov 2010, 09:07 -
50 inch MultiTouch Surface Computer Screen
By freebird73717 in forum Off topicReplies: 0Last Post: 9th Sep 2009, 12:23 -
Big difference viewing backup on 32 inch crt tv and 42 in HDtv
By freebird73717 in forum DVD RippingReplies: 20Last Post: 9th Jun 2008, 18:52
