Results 31 to 34 of 34
It was just a hint from developer that Brazilian translation might be good addition to available translations for Light Alloy
Light Alloy v4.7.5
2013-12-16
Changelog
UI
[ + ] New volume control model.
[ + ] New sound normalization algorithms (compressor and leveler).
[ + ] Radio: added support for https:// links
[ + ] Support for multiple playlists (playlists popup menu->playlist manager).
[ + ] Added new commands to command line: /AudioMode and /VideoMode, if set any of both - player will load in specified visual mode, and last one used will be ignored.
[ + ] Preferences->Interface->Appearance: added *Title format options*.
[ + ] Preferences->Sound: now you can open preferences of any external audio renderer.
[ + ] Preferences->Sound: a few new options.
[ + ] Preferences->OSD->Information line: support for special tags {IFHASVIDEO} .. {/IFHASVIDEO} and {IFHASAUDIO} .. {/IFHASAUDIO} - allows you to avoid output like "x@ (/)" when, for example, no video stream present.
[ = ] File information: ability to save cover in source resolution.
[ = ] Playlist: if files stored below or within same level as playlist file, then they'll stored with relative path.
[ - ] Preferences->Filetypes: fixed player hang with some antiviruses.
[ - ] PLS-playlist parser was broken.
[ - ] Some fixes to skin system.
[ - ] Other less important fixes and changes.
Video Engine
[ + ] Video Decoder: added support for 10 and 16-bit output (madVR required), misc enhancements and optimizations.
[ + ] Video Decoder: added decoding support for WMV 9.1, WMP 9.1 Image V2 (WMVP, WVP2), Avid DNxHD, QT v410, FFV1 and HuffYUV.
[ + ] MP4: support for DNxHD and FFV1.
[ + ] RAW: support for I420, Y800, 4:1:1 y4m files, Y41B/Y42B, 444P and other enhancements.
[ = ] OSD module was rewritten to support high-quality transparency and text scaling.
[ = ] Rewritten audio pitch system in sound module.
[ - ] Video Decoder: sometimes were problems with DXVA1 decoding in Windows XP.
[ - ] AVI: incorrect playback with some files.
[ - ] FLV: fixed playback for some files.
[ - ] OGG: fixed DIRAC and FLAC playback.
[ - ] MKV: fixed seeking on some malformed media files.
[ - ] Subtitles: scale and alignment were broken.
Downloads
http://www.light-alloy.ru/download/Last edited by TheDutchJewel; 16th Dec 2013 at 15:14.
thedutchjewel.defcon5.biz | light-alloy.ru/en -
Current version is 4.8.8
No interest here for this program??Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things.
light scribe not working
By bnts1993 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jun 2009, 15:41 -
ambi light prob
By Mr anderson in forum Media Center PC / MediaCentersReplies: 8Last Post: 9th Mar 2009, 13:01 -
Adjusting amount of light
By ProducerHarley in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 28th Jan 2009, 19:07 -
Low-light shooting
By azinkin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 17th Mar 2008, 16:12 -
Payable portable light?
By B-Twien Bytes in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2007, 12:02
