I have a problem with a file of this type - it's just under an hour long.
If I play it from the beginning (either WMPlayer or VLC), it's fine. But if I try to jump to a later point in the video, it sits there "thinking" for ages - maybe 20 seconds or so - and then, when it's finally found the location, the picture and the sound are WAY out of sync. I haven't been able to work out how far out of sync, because it doesn't even seem to be in the right general vicinity.
Anyway, this contrasts starkly with the behaviour of most AVI/DIVX files I've dealt with, which have no trouble in this situation, and are able to jump instantly to any point in the video, with sound and audio in sync.
So is the file corrupt? If so, is there a (preferably free!) tool out there that could diagnose and fix the problem?
BTW, AVIcodec tells me that the video stream is:
"523 MB, 1334 Kbps, 23.976 fps, 640*384 (16:9), XVID = XVID Mpeg-4, Supported"
The audio information says:
"175 MB, 448 Kbps, 48000 Hz, 6 channels, 0x2000 = AC3, Supported".
And the general details for the file are:
"699 MB (699 MB), duration: 0:54:54, type: AVI, 1 audio stream(s), quality: 72 %".
Anyone got any handy tips... ?
Thanks!
Thanks for the reply. I should have mentioned that I tried that, and it didn't work.
Thanks again. Yes, that's what I suspected. When you say "re-encode it", could you point me in the direction of some straightforward instructions for that? Is it something you can do with free software?
Yeah, lots of free software can reencode it. Open it in AutoGK, hit the Advanced Settings and make sure the audio is 'Original' (so it doesn't get reencoded) and the Fixed Width is set for 640 (the original width). In the main window set the filesize (1 CD most likely), add it to the job queue and hit 'Start'.
Problem with 2.35:1 DivX file in MPEG4 Modifier
By Xoanon in forum Video ConversionReplies: 2Last Post: 26th May 2012, 12:43 -
Lenco portable dvd player DVP-931 MPEG4 playback problem.
By edh in forum Video ConversionReplies: 5Last Post: 13th Jun 2010, 05:58 -
XviD video playback problem
By mictsekk in forum DVD & Blu-ray PlayersReplies: 5Last Post: 20th Jul 2009, 11:16 -
Xvid AC3 file playback problem on Standalone DVD player
By kamol88 in forum Video ConversionReplies: 2Last Post: 21st Mar 2009, 04:38 -
How to playback file of XviD/DivX (AVI) into QuickTime player (Windows OS)?
By Leo99 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Aug 2008, 23:40
