  1. Hi,
    when using AutoGK to add permanent subs to an avi-file the program exited with the following log entries:
    [2012-08-07 10:08:20] AutoGK 2.55
    [2012-08-07 10:08:20] OS: Windows Vista (6.1.7601).2
    [2012-08-07 10:08:20] Job started.
    [2012-08-07 10:08:20] Input file: C:\Film\Awakenings (1990)\Awakenings - Dansktextad.avi
    [2012-08-07 10:08:20] Input codec: XviD
    [2012-08-07 10:08:20] Source duration: 1h 55mn 44s
    [2012-08-07 10:08:20] Output file: C:\Film\Awakenings (1990)\Awakenings - Dansktextad_agk.avi
    [2012-08-07 10:08:20] Output codec: XviD
    [2012-08-07 10:08:20] Audio 1: 105 Kbps MPEG-1/2 L3 2ch
    [2012-08-07 10:08:20] Subtitles: from external file: C:\Film\Awakenings (1990)\Awakenings - Dansktextad.srt
    [2012-08-07 10:08:20] Format: AVI
    [2012-08-07 10:08:20] Target quality: 75%
    [2012-08-07 10:08:20] Audio 1 settings: Auto
    [2012-08-07 10:08:20] Started encoding.
    [2012-08-07 10:08:20] Source resolution: 544x288
    [2012-08-07 10:08:20] Source fps: 25
    [2012-08-07 10:08:20] Analyzing source.
    [2012-08-07 10:40:35] Source has percentage of interlacing in motion areas: 0,00
    [2012-08-07 10:40:35] Source is considered to be progressive.
    [2012-08-07 10:40:35] Output will contain 173600 frames
    [2012-08-07 10:40:35] Demuxing audio.
    EXCEPTION: Unsupported audio type.
    [2012-08-07 10:40:35] Job finished. Total time: 32 minutes 15 seconds
    Can anything be done about this to 'save the day'? Searching high and low I finally found a well-made rip of the movie now this :/
    Thank you.
    Jul 2011
    Denmark
    You could re-rip your dvd and use another audio format... or try Handbrake, Total Video Converter or perhaps Virtual Dub (like this: http://superuser.com/questions/63736/how-do-i-hard-code-a-movie-with-subtitles)
  3. Originally Posted by Nikse View Post
    Thanks Nikse for the reply and the tips.
    I thought I hadn't got any replies - turns out my e-mail forwarding had stopped working... in the meantime I tried - and liked - WINAVI All-in-one-converter.
    No geekery and undocumented features, just straight-forward, fast, good-quality video conversion. In fact I'm sold.
  4. Banned
    Freedonia
    I've been using Xvid4PSP to add permanent subs. If you feed it the subtitle file in Unicode format it can work with any language there is.
