    Jan 2007
    Hi,
    Is there a SVCD2DVD registry setting to bypass the re-encoding of 544x480 material?
    Thank you.
    Mar 2008
    I doubt it. In any case, 544*480 is not DVD compliant. How would it be of any use to you?
  3. DECEASED
    Jun 2009
    Heaven
    Well, if the target is a non-picky hardware player, and if the authoring application is versatile like DVD-lab PRO, there will be no problemos.
    Jan 2007
    Thanks. I tried DVDLab Pro, simple movie setting then Compile DVD. It stops at remux stage telling me that the resolution 544x480 is not compliant and that my video has open GOPs. Is there a turn off compliance setting that I missed?
  5. DECEASED
    Jun 2009
    Heaven
    Surely there is --- the only problem is, I don't remember where to find it anymore
    I have the version 2.24 of DVD-lab PRO, BUT I still haven't reinstalled it after moving house from XP Home to XP Pro.
    Anyway, keep in mind that certain SAPs have difficulties with chapter points when the video has open GOPs.
    Mar 2008
    Thanks for the info. I'm surprised any authoring app. would accept it. DVD-lab PRO? ($$ version only?)
    Jan 2007
    I was able to author it without a menu or chapter points using IFO-Edit>DVDShrink>Nero. IFO-Edit did not produce burnable files, so I tried DVDShrink on the folder. I didn't use DVDShrink to re-encode the video, just to fix the .ifo's (or whatever the problem was). I got a DVD that was playable on two different players (a Samsung Blu-Ray and a Magnavox DVD-R Recorder).
