Hi,
I am trying to convert an mp3 into dv format using ffmpeg, but getting this error -
Thanks,ffmpeg.exe -i C:\WebM\Audio_MP3.mp3 C:\WebM\Output.dv
ffmpeg version N-35462-g61b1d85, Copyright (c) 2000-2011 the FFmpeg developers
built on Dec 5 2011 14:22:27 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 30. 0 / 51. 30. 0
libavcodec 53. 40. 0 / 53. 40. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 51. 0 / 2. 51. 0
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
[mp3 @ 00358660] max_analyze_duration 5000000 reached at 5015510
[mp3 @ 00358660] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from 'C:\WebM\Audio_MP3.mp3':
Metadata:
title : Zippit speech
artist : Unknown
genre : Blues
Duration: 00:00:41.43, start: 0.000000, bitrate: 127 kb/s
Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16, 128 kb/s
[dv @ 01B435C0] Can't initialize DV format!
Make sure that you supply exactly two streams:
video: 25fps or 29.97fps, audio: 2ch/48kHz/PCM
(50Mbps allows an optional second audio stream)
Output #0, dv, to 'C:\WebM\Output.dv':
Metadata:
artist : Unknown
genre : Blues
encoder : Lavf53.24.0
Stream #0:0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (mp3 -> pcm_s16le)
Could not write header for output file #0 (incorrect codec parameters ?)
Rajiv
				Results 1 to 9 of 9
	Tried to give format and type explicitly, but same error -
 Can someone pls give any pointer ... not clear what exactly is wrong here.ffmpeg.exe -i C:\WebM\Audio_MP3.mp3 -f dv -target ntsc-dv C:\WebM\Output.dv
 [mp3 @ 02458740] max_analyze_duration 5000000 reached at 5015510
 [mp3 @ 02458740] Estimating duration from bitrate, this may be inaccurate
 Metadata:
 artist : Unknown
 genre : Blues
 File 'C:\WebM\Output.dv' already exists. Overwrite ? [y/N] y
 Metadata:
 artist : Unknown
 genre : Blues
 Stream #0:0: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
 Stream mapping:
 Thanks.
	Because WMV, MOV, MP4, AVI, etc are MULTIPLEXED streams (Audio and/or Video, etc) inside a Multi-media CONTAINER format, whereas DV is a special type of ELEMENTARY VIDEO (multiplexed with audio) STREAM (no container). Even if the habit is for there to be video in them, mm Containers can usually exist with audio only as well.
 All *.DV streams EXPECT there to be video. That's why it's called Digital Video.
	Thanks very much ..
 One last follow-up doubt .. would it hold true for MXF and GXF formats also ?? I am unable to convert this MP3 into those formats as well ..
 By the way can anyone suggest any good documentation on audio-video fundamentals ? I am a new bee in this world and looking for one such guide ..
	Not sure about ffmpeg's compatibility with & support for MXF/GXF. But those containers are more like playlists (or more accurately - EDLs), maybe they also expect video elementary streams as input. Then you would have the same problem you do with your DV conversion.
 Face it - while there does exist "silent video", for the great majority of time-based multi-media files, you either have AUDIO-ONLY or VIDEO-with-AUDIO. You are starting from an mp3 (AUDIO-ONLY type) and going to a VIDEO-with-AUDIO type. Where's the video going to come from? It doesn't appear in mid-air; you have to create it (separately) and add it as a source.
  AC3 to MP3 Conversion / SynchronisationBy sjdean in forum Video ConversionReplies: 5Last Post: 18th Jul 2010, 21:25
  batch conversion of mp3 filesBy z999 in forum AudioReplies: 2Last Post: 14th Mar 2010, 14:33
  MPEG1 -> MP3 conversion possible in DOS?By Figge in forum Video ConversionReplies: 3Last Post: 25th Mar 2009, 09:05
  MP3 conversion analyzerBy zuja9 in forum AudioReplies: 4Last Post: 14th Feb 2009, 00:53
  XVID AC3 TO MP3 Conversion problem help!By sere83 in forum Video ConversionReplies: 4Last Post: 3rd Nov 2007, 15:55
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
