Converting MP4/AAC to AVI here for watching on TV without direct MP4 support and just wondering if there's an easy way of directly transcoding AAC audio into either AC-3 (Using TMPGEnc AC-3 encoder) or MP3 (LAME)?
I'm currently just extracting to WAV and then converting that, but was wondering if there's a more direct route to doing this?
Cheers.
Perhaps AVIdemux ? Version 8121 release today:
http://avidemux.razorbyte.com.au/ -
Try ffcoder. You can load all the common video containers for converting, but it also gives you an option to either copy or disable the video (or audio) when converting. In fact you can open an MP4 and simply select AC3 or MP3 as the output format. It'll also downmix and normalize the audio if you want it to.
MeGUI is another encoder GUI which is also a very good audio converter. I'm pretty sure you can directly load video files (MP4, MKV, AVI etc) into it's audio section and convert the audio within without the need to extract it first.
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
transcoding mp3 to higher bitrate questions
By spiritgumm in forum AudioReplies: 6Last Post: 28th May 2011, 16:46 -
Found freeware AAC to mp3 converter
By jimdagys in forum AudioReplies: 14Last Post: 22nd Aug 2010, 17:18 -
AAC to MP3
By anirban in forum AudioReplies: 1Last Post: 5th Dec 2008, 12:09 -
AAC 5.1 to WAV or MP3
By Tres_Sol in forum AudioReplies: 1Last Post: 2nd Sep 2008, 22:05
