    I'm capturing video using AmarecTV using the XVID codec
    the recorded clip comes out fine and plays just fine under multiple video players
    but when i insert it into vegas pro the video becomes distorted/discolored looking, both in the preview window and the rendered product
    Pictured in the top is an example of what it looks like in vegas/rendered with it, and below is the normal recorded clip
    what could be causing this? If I capture video using a different codec this doesn't happen, but right now when it comes to recording I really like the compression and quality results I get using XVID
    It's some sort of codec error.
    I see this playing 4x3 FLV files in VLC.
    I've never had time to understand what causes it. I just use something else.
    Also don't attach big images to posts. Nobody likes to scroll left/right.
    The levels issue (brightness) is a studio RGB vs. computer RGB issue . The short summary is Vegas either uses one or the other , depending on the project settings and source format, but expects the other when exporting to certain formats. The "workaround" is to either use computer rgb to studio rgb filter or vice versa.
    What resolution did you record and export in? Sometimes non mod16 resolutions can cause that border smearing in some codecs with some decoders
  4. Member budwzr's Avatar
    That's low quality compared to X264. Maybe time to get current?
