Results 1 to 13 of 13
  1. Hi I'm new here and hope to learn with you
    I know this problem (blocks) exists with DGAVCIndex in file ts*transport demux
    need to solve it error blocks
    I've tried force Core.AVC and DivX H264 decoder. without success. which the final solution?
    is a simple problem but still could not solution
    sorry my english
    http://i49.tinypic.com/2uid8r7.png
  2. nobody? help me please
  3. how to proceed with FFMPEG2Source? I'm using MeGUI and dgavcindex
  4. How did you "force" coreavc or divx h264 ? You can't use it with dgavcindex, you can only use it with directshowsource - I'm assuming that's what you did?
  5. Originally Posted by poisondeathray View Post
    I followed this tutorial http://www.nsaneforums.com/topic/91790-how-to-use-coreavc-with-k-lite-codec-pack/
  6. ts file the rough is perfect, these blocks appears only after passing through DGAVCINDEX
  7. That's not good enough. DGAVCIndex doesn't use external filters . You cannot use it for this
    You need to create a script with DirectShowSource() , along with the directshow filter configured
    e.g.
    DirectshowSource("video.ts")
  8. the script is created avs AVS SCRIPT CREATOR was:
    LoadPlugin("C:\Users\muxado\Desktop\MeGui\tools\dgavcindex\DGAVCDecode.dll")
    AVCSource("C:\Users\muxado\Desktop\AWORK\08-04_21-13-23_Globo HD (por)_Supercine - Tekken.dga")
    Load_Stdcall_Plugin("C:\Users\muxado\Desktop\MeGui \tools\yadif\yadif.dll")
    Yadif(order=1)
    #crop
    LanczosResize(1280,720) # Lanczos (Sharp)
    #denoise
    adding DirectShowSource(video.ts) script would look like?
  9. I'm confused by this, I thought what he was doing was right
  10. You can't use AVCSource as the source filter , replace it with DirectShowSource
    The script would look like:
    (change the path and the name to match, I assume it's .ts extension)
    DirectShowSource("C:\Users\muxado\Desktop\AWORK\08-04_21-13-23_Globo HD (por)_Supercine - Tekken.ts")
    Yadif(order=1)
  11. Originally Posted by muxado View Post
    Thats "right" for directshow playback (e.g. in a directshow media player), not for encoding with DGAVCIndex
    DGAVCIndex (dgdecode.dll) doesn't use DirectShow - it relies on different system
    This is a known, well documented bug with DGAVCIndex. It's depreciated and shouldn't be used anymore anyway
  12. thank you, the blocks are gone after this new script.
    (y) poisondeathray .. Manono
    you hit
