Just wondering, why video files .avi or .mkv play correctly on every computer.
My computer is PAL 50 Hz (25 fps) but it still play content fine of NTSC 60 Hz (23.975 fps).
In VHS era, you have to convert NTSC tapes to PAL somehow before you can watch them, and quality was usually bad.
So why it works directly?
BTW, It seems that all? LCD monitors/televisions has 60 Hz at use, even if my electrial socket gives out 50 Hz.
Why it is so?
But thanks for anwers anyways![]()
Computers are smart devices and have no problem figuring out how to repeat frames to match the monitor's refresh rate. Old analog equipment wasn't very flexible and had to be designed around specific frame rates to keep costs down.
The biggest issue is that computer (and other modern digital equipment) keeps a digital copy of video frames in memory. Those frames can be output to the monitor as many times as necessary to match the displays frame rate. Analog equipment had no memory -- the analog signal had to be displayed as it was received. There was no way to repeat the last frame or field.Last edited by jagabo; 5th Aug 2012 at 12:55.
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
DVD - How do I make all files play automatically?
By gina_here in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2008, 15:25 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45 -
WinDVD7 wont play PAL dvd with mpeg audio correctly ?
By deejay.2001 in forum Software PlayingReplies: 2Last Post: 26th Apr 2008, 15:57
