ProjectX 0.91.0.00
Input file: .TS containing 1920 x 1080 TV stream
ProjectX said "picture decoding not possible, no preview for MPEG-4/H.264". However I can still use it to obtain the subtitle files. But I need to cut out unwanted sessions. In the past, when the resolution was 720 x 576, it was easy to do the job with screen preview. Now I must enter some data inside Navigation. But I am at a loss about what data should be entered. It provides settings including "use BytePos. for cuts", "use GOP number for cuts", "use Frame number for cuts", "use PTS for cuts" and "use Timecode for cuts". I want to cut from 10:58.19 (i.e. 10 minute 58.19 second) to 15:45.11 (i.e. 15 minute 45.11 second). Which setting should I use and what number should I enter?
Results 1 to 1 of 1
Help with ProjectX and Subtitles
By cyberfizz in forum DVB / IPTVReplies: 1Last Post: 26th Jan 2012, 11:38 -
Can Projectx rip text subtitles from TS without demuxing the other streams?
By Talayero in forum SubtitleReplies: 2Last Post: 31st May 2011, 14:29 -
Rip a part from a dvd with subtitles
By itoo73 in forum Newbie / General discussionsReplies: 5Last Post: 13th Feb 2011, 14:20 -
Problem with ProjectX - extraction of subtitles from TS with timing errors
By anthara in forum DVB / IPTVReplies: 1Last Post: 23rd Jan 2010, 08:26 -
Elp! Subtitles Projectx to Avidemux
By PIXCELBUS in forum SubtitleReplies: 1Last Post: 31st Mar 2009, 05:49
