Have a BR that I authored in Encore & turned out fine when viewing on the computer but looking at the final product on TV it looks like my menu highlights didn't turn out so well. I had them as static RED, hover over ORANGE and select WHITE, well on the TV you can barely tell the difference between the Orange & Red.
So I know on DVD it was possible to take an already authored DVD and change the highlights, is it possible (or simple rather than re-author it) for BR is there a tool for this?? Thanks!
Results 1 to 1 of 1
DVDLab Pro problem, menu background colors change when rendered.
By PSPGamer in forum DVD RippingReplies: 19Last Post: 2nd Mar 2011, 21:42 -
Menu button won't highlight
By mattblack in forum Authoring (DVD)Replies: 3Last Post: 21st Oct 2010, 18:45 -
Highlight buttons in DvdReMake Pro menu
By c627627 in forum Authoring (DVD)Replies: 3Last Post: 25th Apr 2010, 19:21 -
How to change highlight delay in authored menu?
By gsh in forum Authoring (DVD)Replies: 3Last Post: 17th Sep 2009, 11:09 -
DvdAuthorGui Menu Jump & Highlight problems
By grannyGeek in forum Authoring (DVD)Replies: 5Last Post: 24th Jul 2008, 23:26
