Hey ladies and gents i have a bit of a problem. I have been using xenonmkv for all my mkv to mp4 conversions for the last few years with not one problem. However recently i ran into my first problem with a movie file not playing. The conversion goes through fine but when i check the properties of the file it says "file length 00:00." It will not play on vlc player, my xbox, nothing. So i will post the original mkv info and then the converted info below.
Note: the original mkv file works perfectly on vlc player but once converted to mp4 it does not. I am running on windows 7 64 bit service pack 1.
My version of xenonmkv is 20110301_39 (war59312)
Original mediainfo mkv file that works fine on vlc player:
General
Unique ID : 215263125474834159654373453427787652149 (0xA1F22B805D509398AB88CAC830475C35)
Complete name : C:\Users\Downloads\movie.mkv
Format : Matroska
Format version : Version 2
File size : 1.22 GiB
Duration : 44mn 52s
Overall bit rate : 3 887 Kbps
Encoded date : UTC 2012-06-30 09:06:54
Writing application : mkvmerge v4.8.0 ('SALVATION') built on May 24 2011 03:12:58
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 44mn 52s
Bit rate : 3 426 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.124
Stream size : 1.07 GiB (88%)
Writing library : x264 core 125 r2200 999b753
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 44mn 52s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 123 MiB (10%)
Default : Yes
Forced : No
Converted file that won't play:
General
Complete name : C:\Users\movie.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 1.15 GiB
Duration : 44mn 53s
Overall bit rate : 3 675 Kbps
Movie name : movie
Encoded date : UTC 2012-08-03 05:35:13
Tagged date : UTC 2012-08-03 05:35:13
Video
Format : AVC
Codec ID : avc1
Duration : 44mn 52s
Bit rate : 3 501 Kbps
Maximum bit rate : 14.7 Mbps
Height : 720 pixels
Frame rate mode : Constant
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.127
Stream size : 1.10 GiB (95%)
Encoded date : UTC 2012-08-03 05:35:14
Tagged date : UTC 2012-08-03 05:35:14
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 44mn 53s
Bit rate mode : Variable
Bit rate : 168 Kbps
Maximum bit rate : 205 Kbps
Channel(s) : 2 channels
Stream size : 54.1 MiB (5%)
Anyone notice the issue here??? And i like using xenonmkv when i want to convert mkv for playing on my xbox console since some of the other programs out there just offer more bells and whistles that i do not need. And xenon is quick and simple and keeps the great video quality with conversion. However if anyone knows of something more modern that is even better and simple than xenon let me know. I want something that will convert any type of mkv file ie. x264, h264 and convert the 6 channels to 2 for use on xbox. However this recent problem is making me reconsider since the conversion finished and said i had no error yet i obviously do....
P.S. there are no codec packs in here that will mess up any other software im running on my pc correct? I have heard of people having issues when they have too many codec packs on a pc or something along those lines?
Program like XenonMKV but with sampling rate conversion?
By shanghei in forum Video ConversionReplies: 1Last Post: 11th Nov 2011, 09:20 -
XenonMKV output mp4 files won't play.
By scarz3 in forum Video ConversionReplies: 1Last Post: 4th Jan 2011, 16:39 -
Windows Movie Maker Importing converted files issue
By gmania in forum Video ConversionReplies: 4Last Post: 14th Oct 2009, 06:57 -
Is it possible to fix a sync issue on a converted file (mp4)
By AndyD in forum AudioReplies: 3Last Post: 23rd May 2009, 22:28 -
Recorded DVD-RW on DVD camcorder...Converted file to .wmv but not working!
By annabelle88 in forum Video ConversionReplies: 3Last Post: 16th Sep 2007, 08:04
