Hi! I have a copy of a Brazilian film Uma Onda No Ar (Something in the Air) and I was able to find a subtitle file after quite a bit of searching. It downloaded as a .txt file. After doing some research (I'm new to subtitle formats), I found that .srt subtitles are formatted as so:
00:05:36,000 --> 00:05:40,000
The phone biII, the new microphone,
the eIectricity biII's aIso overdue.
However, it looks like this in the .txt file:
00:05:36,000:The phone biII, the new microphone,|the eIectricity biII's aIso overdue.
[I'm not sure why the lowercase Ls look like Is, but it doesn't bother me much]
If I edit by hand the subtitle format so that the bottom looks like the top and make the file extension .srt, it works fine (at least until it goes through that section and and goes back to the unedited formatting). But I'd rather not have to go through and edit it for the whole film. Is there another file extension that will allow it to be read in the current format, or is there a program I can use to covert it? I'm using VLC as my media player if it makes a difference.
Thank you very much!
-Eric
You could try subtitle edit. You might have to use the custom import function.
DVD subtitle to text file
By hardy in forum SubtitleReplies: 3Last Post: 27th Jun 2009, 20:31 -
Merging multiple differently formatted text subtitle files?
By fvisagie in forum SubtitleReplies: 9Last Post: 18th Aug 2008, 15:23 -
How to create subtitle file from transcript text file
By amagrace in forum SubtitleReplies: 7Last Post: 8th May 2008, 12:44 -
FLVtool2 doesn't install correctly
By chaosmoon in forum ffmpegX general discussionReplies: 5Last Post: 12th Feb 2008, 20:25 -
Creating a Subtitle File(.sub or .srt) With Just Text(no time sync yet)
By Digistras in forum SubtitleReplies: 3Last Post: 20th Dec 2007, 16:31
