Hi.
I want to make any full bluray 3d movie into one 3d mkv file and i DON'T know which program i use that IT DOESN'T REDUCE ANY OF QUALITY of the full 3d bluray disk.
The 3d movies has except m2ts files and the ssif that i can't see or convert it with tsmuxer or mkvtoolnix.
So what did you suggest me?
I want to stress that I DON'T WANT to reduce any of quality of that movies.
And with the greek 3d subtitles that any 3d bluray movie disk how i can convert them to into the pgs(As it is) subtitles....
A LOT OF THANKS FOR YOUR INFO AND ANSWERS....
I don't know that i quess it support it but the dvdfavb it do RE-CONVERT and loose quality something I DON'T WANT....
Do you know if i can find anywhere the program "3D BD Buster 4.0" Full? -
You must buy 3dbdbuster from http://secure.plimus.com/jsp/dev_store1.jsp?developerId=913502
But I have not tried it. -
And if i can't or don't want to buy it what can i do?
Is there any other FREE program thatr convert ssiff to mkv WITHOUT LOOSING ANY QUALITY....
Does the makemkv program do that convertation or not?Last edited by fits79; 3rd Aug 2012 at 12:42.
No, there is NO free program that converts 3DBD to 3D mkv WITHOUT LOSING QUALITY. Your best bets for FULL QUALITY rips of 3DBD right now are:
DVDFab's Blu-ray 3D Ripper and 3DBDBuster.
***NOTE***: ONLY 1:1 rips from 3DBD to 3DBD ISO are TOTALLY WITHOUT QUALITY LOSS!!
All other rips, even rips that give you "full resolution HD" of both L+R views, must re-encode from MVC to something else (likely AVC). And we all know that ANY TIME YOU RE-ENCODE TO ANOTHER LOSSY FORMAT, YOU LOSE QUALITY, even if it's only a tiny amount.
And those PGS subtitles may or may not do you any good, depending on WHICH PLAYER is going to do the playing.
1. Software player in HTPC - some work, some don't
2. Hardware player in MediaPlayer settop devices, 3D-capable Blu-ray players - none are known to work, but still possible
3. TV - none are known to work
So IMHO, you are back to the drawing board WRT subs.
Need help converting correctly for Samsung LED TV.
By v8n3t in forum Video ConversionReplies: 7Last Post: 18th Mar 2014, 02:53 -
Cannot fastforward DVD's converted to .MKV with MKVTOOLNIX on Samsung LED
By WalkerOfTheDay in forum DVD RippingReplies: 11Last Post: 28th Oct 2011, 06:25 -
How to convert HD MKV Vedio to Avi to play on my LG LED TV???????
By Sh@DY in forum Video ConversionReplies: 27Last Post: 2nd Oct 2010, 07:44 -
cant play mkv with ac3 audio on samsung LE40C530F1W
By swarnpalsingh89 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jul 2010, 14:19 -
samsung 1080p9 wanna play rmvb movies
By phantomeduke in forum Video ConversionReplies: 1Last Post: 29th Jul 2009, 13:50
