I’ve looked at hundreds of tutorials and You tube clips and still can’t find an answer.
I want to add a continuously scrolling text Right to left.
The text is about 4 paragraphs long so the simple scroll things don’t work or loop the text (that I don’t want).
In pro titler I can almost get it to work but after a certain amount of text is typed in it all overlaps itself!!
When I try and stretch the box out all kinds of Sh**t starts to happen. It seems to add points and bend the text etc etc etc.
It also goes Too small to really see what I’m doing or to position anything?
Can anyone give me a simple step by step guide to making this happen??
Pleeeeeeeeese!!!
Make one line of text in a content generated event, and make as many events as you need. Then use Track Motion to connect / scroll / animate them. You need to keyframe the motions.
Forget about those titling tools, they suck. Just for newbies. -
Thanks. I'll give that a go!
However keep an eye out for my new threads on how to use Track Motion!
Although not quite a Newbie I am, if I say so myself, a bit thick!
How can I have mpg with scrolling text?
By RBCC in forum Newbie / General discussionsReplies: 7Last Post: 25th Jan 2012, 04:48 -
sony vegas pro 8 rendering wont render video just audio and text
By bahlue18 in forum EditingReplies: 6Last Post: 12th Apr 2011, 07:31 -
Create scrolling text effect for Movie Credits using avisynth and png image
By wiseant in forum Newbie / General discussionsReplies: 6Last Post: 13th Sep 2010, 02:21 -
Hello..been a long time-Can I upgrade from vegas 5.0 and DVD arch 2.0 to Vegas Pro 9
By arcorob in forum Newbie / General discussionsReplies: 6Last Post: 1st Feb 2010, 20:31 -
removing scrolling text from videos
By planetx in forum EditingReplies: 5Last Post: 27th Dec 2007, 03:53
