when i run it, it creates an MKV of just the english audio track
no video
i thought i followed this pretty close when i set it up
http://www.mediasmartserver.net/2010/03/29/mkv-mania-another-eac3to-gui/
i want english, it's a start but i need the vid too lol
i'm using MPC HC for playback
Results 1 to 14 of 14
I tried MakeMKV but i couldn't see any files in the STREAM folder.
I'll have to mess with it more but here is the mkvinfo
General
Unique ID : 190349885035800842831055267430218950779 (0x8F340DE9E390232DBA408BA609B5687B)
Complete name : D:\AEAC\MyMKVFile.mkv
Format : Matroska
Format version : Version 2
File size : 1.97 GiB
Duration : 2h 8mn
Overall bit rate : 2 194 Kbps
Encoded date : UTC 2012-08-03 02:18:00
Writing application : mkvmerge v5.2.1 ('A Far Off Place') built on Jan 2 2012 23:21:10
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Muxing mode : Header stripping
Codec ID : A_DTS
Duration : 2h 8mn
Bit rate mode : Variable
Bit rate : 2 014 Kbps / 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossless / Lossy
Default : Yes
Forced : No
Text
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Language : English
Default : Yes
Forced : Yes
Menu
00:00:00.000 : en:00:00:00.000
00:04:36.026 : en:00:04:36.026
00:07:32.535 : en:00:07:32.535
00:12:05.183 : en:00:12:05.183
00:17:43.104 : en:00:17:43.104
00:22:58.335 : en:00:22:58.335
00:27:20.889 : en:00:27:20.889
00:30:59.608 : en:00:30:59.608
00:35:07.564 : en:00:35:07.564
00:38:35.855 : en:00:38:35.855
00:43:10.880 : en:00:43:10.880
00:46:43.884 : en:00:46:43.884
00:51:46.312 : en:00:51:46.312
00:55:16.396 : en:00:55:16.396
00:59:57.844 : en:00:59:57.844
01:02:45.679 : en:01:02:45.679
01:07:07.774 : en:01:07:07.774
01:10:06.411 : en:01:10:06.411
01:14:06.359 : en:01:14:06.359
01:18:51.977 : en:01:18:51.977
01:24:19.429 : en:01:24:19.429
01:27:50.056 : en:01:27:50.056
01:31:13.718 : en:01:31:13.718
01:35:33.978 : en:01:35:33.978
01:41:00.554 : en:01:41:00.554
01:47:19.308 : en:01:47:19.308
01:51:35.063 : en:01:51:35.063
01:57:55.485 : en:01:57:55.485
02:03:45.418 : en:02:03:45.418 -
imo - for americans the original german audio with english subtitles is the best way to watch das boot. the english translations/voices just don't cut it. and you really should go with the 3 1/2 hour director's cut...
got subs to work for Bullhead!
i changed some setting in mpc as per...
http://www.avsforum.com/t/1357375/advanced-mpc-hc-setup-guide
toward the bottom there are some subtitle setting suggestionsLast edited by skinney6; 3rd Aug 2012 at 20:32.
thanks for your help!
is there a less expensive mkv conversion?
ill do a new post
mkv to bluray
By redisk in forum Newbie / General discussionsReplies: 5Last Post: 7th May 2012, 18:06 -
MKV with MKV Merge Unicode not compatible with LG BluRay Player
By klode in forum Video ConversionReplies: 3Last Post: 8th May 2011, 04:42 -
bluray 3-d to mkv?
By dave_o in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2010, 08:38 -
Problem with BluRay to MKV
By carbanista in forum Newbie / General discussionsReplies: 3Last Post: 18th May 2009, 23:58 -
Bluray -> MKV
By unknown12 in forum DVD RippingReplies: 3Last Post: 22nd Jan 2008, 16:10
