Is it possible to burn an mkv file onto a blu ray disc and make it playable? Or am I on drugs again?
It depends. What video and audio formats are in the mkv file? What video and audio does your blu ray player support? Do you want to keep it as an mkv file, or if the audio and video are already blu ray compliant, would you like to make it into a blu ray video format before burning?
If your blu ray player supports playback of mkv's, and the existing specifications found in your mkv file, then you should be able to burn straight to a disc as data.
If you want blu ray structure, and the existing video and audio conform to blu ray specs, you can turn it into a blu ray video without re-encoding using Clown BD. It can also convert some non conforming audio types to AC3 for you. -
Or convert to avchd/blu-ray with avchdcoder, bdtoavchd, multiavchd.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Blu-ray converted to .mkv now i want it back to blu-ray structur ?? help
By Trigarr in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Oct 2011, 12:34 -
Blu-ray remux (.mkv) to Blu-ray structure again ?? how
By Trigarr in forum Authoring (Blu-ray)Replies: 1Last Post: 20th Oct 2011, 08:44 -
Multiavchd..Need Help..MKV-BLU RAY-- Freezing on Blu Ray Menu!!
By Thuglas in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Sep 2010, 22:58
