I just bought this camera and I was wondering if it's better to use 1080i or 1080p in the settings? I want the absolute best picture quality possible.
Thanks,
				Results 1 to 14 of 14
	depends on what you are shooting and what the desired end format is going to be. --
	I'm shooting a lot of moving objects like animals, people, sports matches, etc. Some from far away so I use the zoom a lot. The camcorder outputs .mts files and I don't want to lose any quality so ideally I wouldn't convert any of the videos- I'd just watch them as is.
	if you want smoother motion then 30i is preferred. it will give you 60 individual fields/sec. 30p would be used for computer or online video but only provides 30 frames/sec.
 [edit] looks like that cam can be set to shoot 1080 60p. you may as well use it and get the best of both worlds.--
	Some players from Sony and LG are compatible with AVCHD 2.0:
 LG BD570/BD560
 Sony BDP-S270/S370/S470/S570
 Sony 2011 *80 series support AVCHD 2.0 and 1080/60p files with a FW upgrade.
 http://www.avsforum.com/t/1286430/1080p60-1080p50-playback
	Great, thanks a lot. No wonder my videos weren't looking sharp!
 By the way, do you happen to know if a graphics card with hardware acceleration will help playback these .mts files? The computer I'm using for playback is an old socket 939 with fx-53 processor 1gb ram. It plays the videos in slow motion (100% cpu load), even with CoreAVC and ffdshow installed.
 There are some AGP graphics cards on the market that have hardware acceleration like CUDA.
	probably not. agp cards are old enough that gpu CUDA help from them may not be enough to play 1080p avchd files at real time. you really need to update to a modern cpu/motherboard. --
	This might help:
 http://zachsaw.blogspot.com/2009/06/ati-hd-hardware-accelerated-dxva-for.html
 http://zachsaw.blogspot.com/2009/08/watching-hd-video-in-mpc-hc-dxva-for.html
 Doubt it will do 1080p60.Last edited by jagabo; 26th Dec 2012 at 09:03.
	I buy a CX260VE before 15 days. I have one problem. When i record video (60i or 60p) is some random form, there is a recording messange, THE SAME as when i record photos. So even if i never press the photo button, there are some photos recorded!!!! Is this a bug, a hardware problem or anything else (soft)? Any idea please????
	Doesn't it take a picture if somebody is smiling at the moment? Maybe this feature is on by default.
  SONY HDR-AX2000E: "only" 1080i via HDMI, not 1080p?By flashandpan007 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 19th Jul 2011, 05:50
  Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080iBy adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37
  sony hdr-sr12 new HDD camcorder is 1080p or 1080i?By deejay.2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 31Last Post: 8th May 2010, 14:04
  Sony Bravia KDL32V4000 Can it show 1080p or 1080i?By rob_a in forum DVB / IPTVReplies: 0Last Post: 21st Dec 2009, 16:20
  1080i vs. 1080pBy Shibblet in forum DVB / IPTVReplies: 31Last Post: 27th Sep 2008, 14:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
