I want to be able to rip a DVD to .avi and at the same time hard code two different languages to the .avi file. e.g. Czech at the bottom and English at the top.
Unfortunately, AutoGK gives me the option to hard code one language.
Is it possible to do this? Otherwise, I would need to encode the file twice to achieve this and thus lose quality and time.
Rip means to copy the contents from a CD, DVD or BD disc to your PC. That is it. So you cannot "rip to AVI". You mean rip and then convert.
This subject has come up before and there is an AviSynth plugin that can do this, but I don't remember what it is. If AutoGK can accept AviSynth scripts then you may have to use AviSynth to do this. I think there is also a VirtualDub plugin that can do this. If you can find out how to do it in VirtualDub it may be a lot easier to just use it for encoding to AVI. -
I ended up finding a solution using:
Virtualdubmod
VOBsub
I used Vobsuc to rip the subtitles into .idx format for Czech and English.
I then used the vobsub filter in virtualdubmod to add both of these to the film. Then I encoded into .avi
The only problem I have is now when I play it on my TV it's on 4:3 format.
However, When I play the original DVD on my TV it's in 16:9 format.
The resolution on both the DVD and .avi are the same (720x576) so I'm not sure why there is this discrepancy? -
It's not 4:3. It's in the same ratio as the source (720x576), which is 1.25:1 or 5:4.
Either you can set a 16:9 Display AR in something like MPEG-4 Modifier (which might possibly not be honored by your player), or you can resize it to some 1.78:1 resolution, one such as 624x352.
How to hardcode .sup subtitle file to a mkv movie?
By CodeGEN in forum SubtitleReplies: 6Last Post: 13th Mar 2017, 03:24 -
With autogk no subtitle load window after clicking ctrl-f8
By 3l8x in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2010, 16:19 -
DVD Decrypter, AutoGK and Subtitle Times
By sambat in forum Video ConversionReplies: 5Last Post: 13th Feb 2010, 06:55 -
Multiple audio languages and subtitle languages
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 15th Aug 2009, 12:44 -
Want to use Autogk to add subtitles but can't find external subtitle option
By godfist314 in forum SubtitleReplies: 1Last Post: 15th Jul 2008, 19:11
