I'm using Pan Crop to resize and reposition a still image so I can fit text above or beneath it. Fine.
Now then what if I wanted to leave the image the same size on the screen but animate a "pan" across the image for example.
I can’t use the Pan/crop to create the animation as this will spoil the size and position of the image that I have just set?
Is there a way I can animate (pan or zoom) my resized image?
Can I add a second keyframe to the same clip?
Is there a way? (apart from exporting the image and resizing and repositioning it in another program and reimporting etc etc (Tedious!!)
Simply use the "Track Motion" tool.
What it does, gives it its name. It lets you slide the track around or put it into 2.5D motion. It's not really just a PIP tool.Last edited by budwzr; 1st Aug 2012 at 13:43.
cant open sony vegas pro 11 'event pan/crop'
By kitsuneee in forum EditingReplies: 7Last Post: 4th Apr 2013, 23:11 -
Opening Pan/Crop Window (Sony Vegas)
By SaintAin in forum EditingReplies: 2Last Post: 25th Jul 2012, 10:39 -
Sony Vegas Movie Studio 9 Platinum: Event pan/crop keyframing problem
By Dude E. O'Loo in forum EditingReplies: 2Last Post: 22nd Jan 2012, 20:09 -
Cant open the pan/crop window in sony vegas 8.0 pro
By Anonymous5494 in forum EditingReplies: 2Last Post: 28th Jun 2009, 03:25 -
Vegas - Sony Borders Fx, Stills and Pan/Crop
By fredfillis in forum EditingReplies: 3Last Post: 19th Aug 2007, 17:17
