This question gets asked a lot, but I have never really found a good answer.
I am looking to either extract a section of a VOB, or edit a ripped VOB. I plan to burn the smaller VOBs onto a mini DVD. Since I need to find a specific scene within a VOB, I am not able to accomplish this task with VOB Splitter.
Also, I do not want to re-encode the MPEG file/VOB, since the factory encoding is likely to be much better than anything I would do.
Thank you.
Smartripper does allow one to extract a particular chapter.
But I should clarify question. I am looking to extract or edit a section within a chapter. So I will need some sort of application that lets one see the starting and ending frames. -
DVD2AVI springs to mind, try that... You should be able to load one vob and extract a particular scene, then encode it with Tmpgenc (latest version) the DVD templates are not bad (yes i know you didn't want to recode, but the results should be ok
Hey my 100th post!!!
Extracting/editing security footage
By lisabee35 in forum Video ConversionReplies: 9Last Post: 15th Jul 2013, 11:03 -
Extracting frames from VOB files
By omkar.parkhi in forum Newbie / General discussionsReplies: 10Last Post: 21st Jun 2011, 16:25 -
Extracting/Editing DTS-HD
By sparktank in forum AudioReplies: 3Last Post: 28th Apr 2011, 12:11 -
Extracting Subtitles From VOB Problem
By darkdream4 in forum SubtitleReplies: 7Last Post: 6th Jan 2010, 14:17 -
By darkdream4 in forum DVD RippingReplies: 1Last Post: 6th Jan 2010, 05:28
