Hi there,
I'm trying to update the firmware for my BD player, however Samsung firmware is only Windows compatible. The file is compressed and there is no Mac software I can find that can uncompress it (it's a .sec file). Samsung's reply is sorry. Essentially, if someone can either host the uncompressed version of the firmware update for download, or recommend a Mac program that uncompresses .sec files it would be much appreciated.
If you are updating the FIRMWARE then you don't do anything with the .sec files. Try reading the instructions which I easily found via a 30 second Google search:
http://downloadcenter.samsung.com/content/FM/201104/20110401141955778/USB_Upgrade%5Beng%5D.pdf -
While I appreciate your condescension, I have already read that page. According to my search results, a .sec file is a compressed file format. My Blu-Ray player will not recognize the file until it is uncompressed. If I can obtain an uncompressed version of the file, I can slap it onto a flash drive and there is no problem, however the compression format .sec is only compatible with Windows. If there is something I'm missing in all of this, please do explain, but I don't need the sarcasm.
These instructions say absolutely NOTHING about un-zipping an .sec file. Read it again. You un-zip the ZIP file
then place the contents to a blank USB stick. Whether the files need to be inside or outside of the IMAGE folder is anyone's guess.
Try it both ways. -
you're definitely missing something....
inside the "zip" file that is for all windows and macs is a folder called image and inside it are a bunch of files not just one "sec" file. it's the folder called image with all the files inside that needs to be in the root of the usb drive.
[Attachment 13296 - Click to enlarge]--
Samsung BD-D5300 External HD
By pacman2000 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th May 2012, 16:52 -
Samsung HT-D5300
By aakakar in forum DVD & Blu-ray PlayersReplies: 15Last Post: 12th Dec 2011, 17:16 -
I've killed my Samsung BD-P1620 with firmware update :(
By DimensionOe in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th Jan 2010, 19:13 -
Samsung SH-S183L firmware update problems
By Dr_Layne in forum DVD & Blu-ray WritersReplies: 1Last Post: 8th Feb 2008, 10:36 -
Samsung TX-S3082WH (HDTV) firmware update via USB???
By Crazyj32 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 19:47
