I have got a problem with Panasonic MPEG1 encoder 2.30 standalone ver. during AVI (DivX)conversion. A bitrate was set 1536kbps and therefore VBV buffer size had been fixed to a small value of 40kB. After encoding about 100 MB of output file the program stops with an error message:"Video data rate or VBV buffer size is too low". I can not increase the bitrate upto 1858 kbps or highier to allow the software 100kB VBV (Auto or manual) setting because the movie will not fit into 2 CD-R.
Is there any patch or workaround to avoid this problem?
Results 1 to 1 of 1
panasonic ag 8700 TBC problem
By thegreatbear in forum RestorationReplies: 3Last Post: 19th Aug 2014, 09:19 -
Panasonic DV Firewire problem
By darrenkarp in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2010, 13:28 -
panasonic self check problem
By tony blaze in forum DVD & Blu-ray RecordersReplies: 18Last Post: 13th Jul 2010, 22:57 -
Mencoder problem: BUFFER UNDEFLOW at stream 0, raising muxrate to 11088
By fvisagie in forum Video ConversionReplies: 0Last Post: 29th Apr 2009, 16:43 -
issues with wmv for xbox encodes (buffer problem)
By DsOft in forum Video ConversionReplies: 0Last Post: 3rd Dec 2008, 11:52
