Hi guys,
I've built a videowall, and we're not sure if we're going to use 3x3 or 3x2 yet. But I wanted to ask some general questions regarding codecs..
If we use 3x2 setup, I need to play a video that is 3840x3600 (25fps). What codecs can I use for this? Everything I try just gives me down-scaled renders.
Thanks in advance,
YouTube supports resolutions up to a maximum of 4096x2304, and it's h.264. I also know ProRes can support at least this resolution. So, it's a good place to start.
x264 has no problems with that frame size. Whether you can decode it in real time is the real question. Xvid supports it (probably Divx too) and is easier to decode.
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 14:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
Re-Codec
By Casper_H in forum AudioReplies: 1Last Post: 21st Feb 2008, 08:10
