I've been using SUPRip to convert sup's to srt format, but i'm tired of sitting there for like an hr just making a srt file. Is there any other way to do this? I see sum files for subrip that has a bunch of character matrix's, but there doesn't seem to be a way to use them with suprip.
Is there any other program i can use to make a srt file or is there anyway to use a character matrix with suprip so that i don't have to sit there for hours making subs?
Results 1 to 9 of 9
Yeah, i know. Is there a database for subtitle edit? Because it's still missing a lot of words that don't even show up wrong sometimes. Like H(& instead of Hey. It will completely skip that even though it's clearly not correct.
Under Spell Check - Get Dictionaries you can add dictionaries to be used during spell check and OCR ...
After you have your draft SRT file,
www.SubtitlePlus.com may has the software for you to editing, formatting, rendering.
It automatically does spell check, like Microsoft Word.
Check the manual to see if it is OK.
http://www.subtitleplus.com/splus/SHelp/SplusVisualApp12M_HELP.htm
I've described this a couple of times. So I'll just post the link. If the source is English subs, I've had very good luck with DVDSubEdit automatic OCR:
https://forum.videohelp.com/threads/281310-How-to-convert-IDx-Sub-to-Srt-w-o-typing-a-m...=1#post2132142http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
subextractor (https://subextractor.codeplex.com/) or BDSup2Sub++ (https://forum.doom9.org/showthread.php?t=165416) might also be worth a try,..
Letter being covered up by the letter next to it
By Cyan in forum SubtitleReplies: 4Last Post: 2nd Jan 2012, 08:05 -
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 07:20 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 01:46 -
How to rid of N letter in .srt subs ?
By mahogany in forum SubtitleReplies: 11Last Post: 15th Nov 2009, 14:19 -
When using avidemux to convert idx to srt, it only sees half the letter....
By Kaminoshi in forum SubtitleReplies: 0Last Post: 12th Jul 2008, 21:50
