  1. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    I posted a Document and a video here that shows how to use Aegisub to create an .ssa format subtitle document and then use it with Virtualdub and it's subtitle plugin to modify subtitles to display where and how you want. Basically Virtualdub subtitle plugin doesn't recognize some tags like \pos for position but does recognize others such as \an1, \an2, etc for positioning different locations on the screen and you can fine adjust with MarginL, marginR, and MarginV in the ssa document. The document shows 2 different ssa files and the results and explainations and the video (49 MB) shows actually creating hard coded subtitle file with virtualdub and ssa file.
    The links are:
    http://files.videohelp.com/u/214352/SSA%20Script%20Info.docx
    http://files.videohelp.com/u/214352/videohelp_4_.avi
    I added the video above with subtitles and the actual .SSA subtitle document at:
    http://files.videohelp.com/u/214352/untitled%20subtitled.ssa
    http://files.videohelp.com/u/214352/videohelp%20subtitled.avi
    There is also an excellent document on .SSA format and what each tag is/set as at:
    http://moodub.free.fr/video/ass-specs.doc
    And .ASS tags at:
    http://docs.aegisub.org/manual/ASS_Tags (thats ASS<Underscore>Tags)
    I tried to cover most of whats left out in some helps. Hope they help.
    Budman1
    Last edited by Budman1; 3rd Aug 2012 at 00:18. Reason: Changed more descriptive Title to Include VirtualDub for those using it
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Why not use the TextSub filter from the VSFilter/DirectVobSub package, instead? I don't recall ever having a problem with positioning and .ass subtitles using it with VirtualDub.
    Could that be running into limitations of the SSA format, though? I've never really worked with .ssa subs, just .ass.
