I'm looking to get a DVD/Blu-Ray player that's like the PS3 and will be able to play 'data' discs, which are DVD discs that have video on them, but aren't in the standard DVD (VOB) video format. It's more like treating a DVD disc as a USB drive.
Also, I need the player to be able to handle HD video such as MKV, and TS files.
I don't want to have to convert them to the standard DVD or Blu-Ray structure in order for them to play properly. I want to be able just throw on a MKV/TS files on a USB drive, or DVD-5/9 disc.
Results 1 to 17 of 17
You (almost) positively WON'T find a DVD player that plays HD files - they're SD only. Only BD (or the defunct HD-DVD) players, or generic "Media Players", play HD video.
Yes, some BD players will play MKV (more arriving every day), but for true "universal" compatibility, your best bet is either a generic Media Player like WDTV Live, or an HTPC software player (I like XBMC).
Scott -
Since your location is unknown it is hard to recommend specific models. All I can tell you to do is look at LG's Blu-Ray product line. I have seen recent US models from LG that will play MKV and TS files.
However there are going to be restrictions on what a Blu-Ray player will support within these containers. If you find a player you like, download and read the manual carefully to be sure the player supports the video, audio and subtitle formats you want to use, not just the container file formats. For example some LG players won't play DivX videos, but will play Xvid videos. Neither GMC or QPEL is likely to be supported by any BD player. Some players only play subtitles from external files. Many only support UTF-8 or ANSI text encoding for subtitles. Also make sure the player can read NTFS formatted drives, and large files. Some players may have restrictions on HDD capacity or USB flash drive capacity too.
Like Cornucopia said, you may find a media player or HTPC is a better choice for your situation.
USB 2.0 or BD media are better choices for playing HD video files than DVD9. DVD9 will have a layer break which causes a pause during playback. I have heard the disc drive may be louder too when playing HD files on DVD media.Last edited by usually_quiet; 30th Jul 2012 at 10:46.
@usually_quiet
I'm from the US. I want to stay away from storing my media on HDD's since I don't trust them to last as long as discs.
So, even though the WDTV looks great, it doesn't play discs.
I'm not concern about subtitles, or any of that. Just need a BD player that will play MKV/TS files on data DVD discs. -
I have been looking at a LG BP220 for myself. It's a budget 2D only player with limited Smart TV aps and a wired LAN connection. It can play video files from DVD+R DL and USB sticks. It plays MKV files, H.264 and MPEG-2. It doesn't list .ts as a supported file extension, but MPEG2 TS is listed under "Codec Format" You can download the manual from this page http://www.lg.com/us/support-product/lg-BP220# If you need more features, LG has 3 additional BD players listed at its website.
I'm backing up my HDTV captures on DVD+R DL now too. I hope to switch to BD media at some point when I get a BD burner. Verbatim BD-R is the same price as DVD+R DL but holds 25 GB. -
LG makes the BP320 which is a step up from the BP220.
The main difference that I see is that the 320 has Wi-Fi built-in whereas the 220 does not. Not sure if there is another difference or if it is just that simple.
The price difference seems to be about $30 US dollars (with the 220 being $90 and the 320 being $120 where I checked on-line).
*** Now that you have read me, do some other things. ***
I've never run across a MKV that uses OGG audio (I assume that is what you mean by MKV endoded with vorbis)
Yeah, all of my personal encodes are with Vorbis (OGG).
If OGG is not supported by any Blu-Ray players out there within the MKV container, is there a way I can quickly change the audio stream of the MKV to something else?
What do you guys suggest is the best audio format I use with MKV's?
Best being, smallest size, with decent audio, that's the most compatible with Blu-Ray players.
Of course, I'd like to know first if there are any Blu-Ray players that will support OGG first. -
I only have a PS3 at the moment (and my computer) but like you I've been thinking of buying a Blu-Ray player with good MKV support. I looked up the LG website and the LG BP220 says nothing about OGG/FLAC/Vorbis at all.
I doubt you'll find a Blu-Ray player with OGG audio support (in a MKV). Perhaps a media player (like the Western Digital LiveTV products) can do it. I'm not sure though. Even then I bet the answer is "no".
You would be better off sticking to AC-3 in the future (or AAC-LC)."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Yes you can do that. I'm not sure what program would be best for that though as I've never had to deal with OGG in a MKV but there's probably some program out there that will do it in one step for you.
Maybe try rebox.NET
If you want to play MKVs with audio encoded with Vorbis (OGG) you need to use a PC or a media player, not a BD Player.
The primary purpose of BD players is to play regular Blu-Ray and DVD video. Playing media files is a bonus feature. They have many more restrictions regarding what they will play than a media player or PC.Last edited by usually_quiet; 14th Aug 2012 at 22:25.
Burning avi/mkv/whatever files as a BD-R/RE data disk for my Blu-Ray player
By Braindrain in forum Authoring (Blu-ray)Replies: 8Last Post: 25th Jul 2014, 07:13 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Blu-Ray player that plays MP4 and/or MKV from disc (not only USB)?
By cosmin in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Dec 2010, 22:49 -
Looking for a Blu Ray Player that plays Hulu its my first Blu Ray Player
By marionr26 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 7th Dec 2010, 10:56 -
Is Backing up DATA in Blu Ray Recordable Discs Reliable?
By faramith in forum ComputerReplies: 9Last Post: 8th Oct 2009, 09:46
