    Jul 2012
    New Zealand
    What is the easiest, best way, program to black out the video portion of an avi file but leaving the audio
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    AviDemux or VirtualDub can do it easily but you will need to re-encode the video and lose quality.
    Dec 2005
    Canada
    Starting post #6 refers to using the curve editor on part of the video and 'Smart Rendering' to ensure that the encoding is confined to that area.
    Smart Rendering assumes that the output codec selected is the same as the input.
    https://forum.videohelp.com/threads/317036-Edit-Avi-VDub-VDubMod-Nandub?p=1962577&viewf...=1#post1962577
    There's a demo here.
    http://www.youtube.com/watch?v=2MWoVY9mYbk
    Jul 2012
    New Zealand
    will look at those thanks
