Hello,
With DVD it is possible to create multi-lingual video.
Is there a movie container, that would be able to create a multi-lingual video or only authoring as DVD can realize that??
How one would select the language?
Pushing this further with adding multi-lingual subtitles.
If possible, how to achieve this with ffmpeg?
Take for instance a DVD rip as source.
Thanks for answering or providing an URL.
Re: http://ffmpeg-users.933282.n4.nabble.com/Preserving-subtitles-when-transcoding-mkv-to-...td4238596.html
Results 1 to 11 of 11
MKV easily supports multiple audio and subtitle tracks. Other containers can do this too, but with more limitations.
Selecting the audio and subtitle are done just like for DVD - by remote control or accessing the Audio or Subtitle selection on a software player. -
Look, ALL container formats, with the possible exception of RM or OGG, support multiple streams of audio. Believe it or not, they also support multiple video streams as well.
What really is the determining factor is if the PLAYER in question supports that feature in that format. That is why DVD is clearly easy to work with multiple audio - because support for it is MANDATED for ALL players by the dvd spec.
Mkv was explicit in its support for multiple audio from the very beginning, so it is no surprise that PLAYERS THAT SUPPORT mkv usually support ma. There are many players that don't support ma at all in any format, but you don't notice because they don't support mkv anyway.
Bottom line - it has to be taken into account and coded for in the player app.
Scott -
^ Yes, but VirtualDubMod is outdated and useless, except for certain random amateur "releasers" of course.
Back from holiday.
So as a try out can some give an URL to make a multi-lingual MKV video from DVD rip.
Can one make a virtual MKV from a DVD rip? I mean keep the DVD structure and have a MKV container that would point to the DVD directory structure.
Thanks -
I don't think any file format can retain the menus. The closest you could get would be the older divx plus that would have a menu.Originally Posted by feelart
I think you would be better off just ripping to an iso and keep the original dvd intact. If you can't playback an iso on your intended device than I think you have to sacrifice the full features of a fully authored dvd otherwise.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Before you go any further, you need to figure out how you intend to play your media. Using hardware devices? or Software (pc/mac)? Showing via what interface(s)?
Like I said before, THIS will determine what you should go for. Then, once you know what you should go for, you can get tips on how to best get there.
You work backwards from your final destination and pick paths that get you to that destination, not the reverse.
Scott -
Well, I wish to play from smart tv which pumps it source from an usb hdd.
Present.y, works well with dvd, but at each change of vob files it takes a while to transit
How to create video DVD from DAT file
By abhishekm in forum Authoring (DVD)Replies: 2Last Post: 20th Sep 2011, 14:28 -
How to create the file structure of a DVD video disc?
By mrpop151 in forum Authoring (DVD)Replies: 2Last Post: 16th Nov 2009, 12:51 -
How do I create a continous MPEG2 file from a DVD with video from menus
By porchmonkey in forum Authoring (DVD)Replies: 3Last Post: 5th May 2009, 06:48 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 03:01 -
Converting Bi-Lingual VCDs to Single Language MPEGs
By HHBear in forum Video ConversionReplies: 3Last Post: 13th Feb 2008, 23:05
