Bahman can you tell me advantages of using get_iplayer over rtmpdump ? can we get old iplayer shows list that are not in iplayer website which recently removed from site?
Furthermore, for rtmpdump how i can specify to save the output of rtmpdump in another drive? does saving output to external or usb drive affect the speed of download?
Results 151 to 180 of 194
RTMPDump v2.4-35-ge0056c5 (c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL Connecting ... INFO: Connected... Starting download at: 0.000 kB INFO: Metadata: INFO: duration 12191.89 INFO: moovPosition 36.00 INFO: width 640.00 INFO: height 360.00 INFO: videocodecid avc1 INFO: audiocodecid mp4a INFO: avcprofile 77.00 INFO: avclevel 30.00 INFO: aacaot 2.00 INFO: videoframerate 25.00 INFO: audiosamplerate 44100.00 INFO: audiochannels 2.00 INFO: trackinfo: INFO: length 12188001.00 INFO: timescale 1000.00 INFO: language eng INFO: sampledescription: INFO: sampletype amf0 INFO: length 12191881.00 INFO: timescale 1000.00 INFO: language eng INFO: sampledescription: INFO: sampletype avc1 INFO: length 12191894.00 INFO: timescale 1000.00 INFO: language eng INFO: sampledescription: INFO: sampletype mp4a 1145416.323 kB / 11780.44 sec (96.6%) ERROR: RTMP_ReadPacket, failed to read RTMP packet body. len: 68977 1145437.553 kB / 11780.44 sec (96.6%) INFO: Connection timed out, trying to resume. Resuming download at: 1145437.553 kB WARNING: HandleInvoke, Sanity failed. no string method in invoke packet WARNING: HandleInvoke, Sanity failed. no string method in invoke packet
Code:RTMPDump v2.4-35-ge0056c5 (c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL ERROR: Last tag size must be greater/equal zero (prevTagSize=2012410200) and sma ller then filesize, corrupt file! INFO: Command exit code 1 (raw code = 256) WARNING: Retry recording for 'Olympic Taekwondo - London 2012: Semi-finals (p00w 32b5)' INFO: File name prefix = Olympic_Taekwondo_-_London_2012_Semi-finals_p00w32b5_de fault
quackeroats did you succeed in resuming from 1145437.553 kB / 11780.44 sec (96.6%)?(resume in same incomplete file)?could you let me know how as i have same problem with some files?
By using get_iplayer you don't need to track packets so as to find stream links. Get_iplayer do all of these works it self and then tries to download stream via rtmpdump at the end.
if they have removed from site, they have removed that from the server too. So, you can't.
just give it a path, like this: -o "D:/folder1/folder2/folder3/Olympic.flv"
and if you want to save on a USB drive, it depends on your internet speed, if you are downloading streams with over 16MB/s, yes it will effect! -
If you are asking whether get_iplayer can download streams in excess of 4Gb then no it can't. The limitation is rtmpdump which get_iplayer uses to download the rtmp stream.
The limitation may be as a result of how rtmpdump is coded as it may use file pointers which are only 32bits in size, I.e. 4Gb. rtmpdump might use OS dependent file pointers which will be limited by the word size of the OS, for example 32bit Windows. A 64bit build of rtmpdump May not have this restriction, I have not looked at the source code so cannot say for sure.
This is not a major issue however as you can split the downloads, see previous posts in this thread for details. -
I've never used get_iplayer before, but I've got it installed. Since the url I'm trying to get is so long, I set up the command in a batch file and set a stop for 60 seconds.
get_iplayer --raw URL --mode flashhd --stop 60
I put the batch file at the root of my system drive and double-clicked on it (Windows), and now my command window just has a bunch of text scrolling by at really high speed. After several minutes, I interrupted it with a Ctrl-C, because obviously something was wrong.
I opened the Recordings Folder and it was empty.
I guess I don't know what URL to use. I used Coojah to try the one that ended in mpeg.ts and the one that ended in .m3u8.
Perhaps ffmpeg is the better option for me, but I wanted to start and stop at specific points in the program and I don't know how to do this with ffmpeg.
Any hints would be welcome
Edit: I just realized I'm posting in the BBC Olympics thread and I'm trying to download from the NBCOlympics site - - Silly me! Let me guess - the guidelines for using get_iplayer won't work for me?Last edited by tluxon; 22nd Aug 2012 at 17:48.
when i use RMC to "Fix FLV" iget a duration of 7680.52, i resumed get_iplayer to --start=7680.
do you have methods to join the 2 files? what about miising frames, not sure if it has that big an impact
on the video.
i am thinking convert to mkv, and use mkvmerge -
I have not bothered joining the files back together, quite happy with 2 or 3 separate parts, so can't help there.
You will most likely have missing frames of data between the two parts, though you can probably limit this by recording the first part with a stop time like 7200, then restart from there. Personally I have found that subsequent parts have the audio stream shifted by 4 seconds which I need to correct with ffmpeg. I have not bothered to see how seamlessly it all fits together as I am not going to keep this beyond finding the time to watch it.Last edited by mikethetv; 23rd Aug 2012 at 16:07.
does any one else get this error trying to view video in bbc sport website ?
This content doesn't seem to be working .try again later. -
You guys are awesome. Thanks for the information.
I'm having the same problem, try FLV extract and MP4box/Yamb instead?
I don't suppose you don't happen to have a link for that build do you? I can't seem to find it anywhere.
edit: Thanks Bahman!
I found an easier solution in Firefox by opening Tools>Web Developer>Web Console to monitor all traffic and set filter for "open.live.bbc".
There are a number of things that can cause that in my experiance from being temporarily unavailable on the server to AdBlock or similar software blocking referral links or some such and even Firewall issues. Also if your internet speed is very slow the servers seem to refuse the connection. I'd start by trying a different browser .Last edited by Chug a Bug; 31st Aug 2012 at 12:31.
someone just pointed out to me somewhere else that the geo-blocking for the youtube olympics videos are no longer being geo blocked.
hence everyone one in the world can get it (i think)
, it might be more "stable" to get a m3u8 link from youtube.com/olympics then from BBC itself using ffmpeg -
Fantastic thread.
I tried rtmpdump first, and got that working, but then switched to Get_iPlayer as it's simpler.
Managed to download several videos including the Rhythmic Gymnastics and the Men's Road Race.
I'm stuck however on the Men's Single Final:
The link is http://www.bbc.co.uk/sport/olympics/2012/live-video/p00w314t
I have now tried four times to download this using the following command:
Code:get_iplayer http://www.bbc.co.uk/sport/olympics/2012/live-video/p00w314t --raw --modes flashhd --force --start 7565 --stop 16830
On each occasion the dl stops between 1.9Gb and 2.1 Gb with the Error:
FLV file contains neither video nor audio, aborting! -
Hi. Sorry but I am new to this and do not understand a word of any of it.
Please can you tell me how to download AdobeHDS and what I am supposed to do? I want a programme that will capture the fragments and join them together to make an flv that will play.
All this code means nothing to me and bTW, Coojah does not work on my computer - running it stops ANY web page from loading.
So how do I get the application that will download each fragment? It tells you here:
http://ingvar.blog.redpill-linpro.com/2012/05/31/downloading-hd-content-from-tv-nrk-no/
what do do but when you click on it you get a text file on screen of the script, not the application. And the term "put it in "~/bin" again - I do not understand this.
So for example, Archery session 1 on 28 July is on the video on this page
http://www.bbc.co.uk/sport/olympics/2012/live-video/p00w2r8y
So what do I do to capture it? Thanks. -
I'll give Bahman a break, it's
get_iplayer --pid= p00w2r8y --modes=flashhd,flashvhigh,flashhigh,flashstd
you can cut edit the --modes= option to give the resolution you want i.e. 1280x720,832x468,640x360 to suit if you wish
if you're outside the UK you'll need a proxy/VPN. Good luck.
Sometimes, not sure why, it could be the recording modes is not set as default. You can force it as per above. -
Can anybody tell me how to download this in HD http://195.188.87.10/iplayer/episode/p00w33bq/hd/Olympic_Gymnastics_Rhythmic_London_20...lAround_final/
Please help !!!! -
get_iplayer --pid=p00w33bq --modes=flashhd
N.B. for anyone else with a similar question just replace the PID in the above line. The PID can be found in the URL it begins with "b" or "p" i.e.
.../iplayer/episode/p00w33bq/.... -
Dear Chug a Bug,
Thx for your help but I can not get it right
Can you guide me step to step how to do it
Thank you Very Much for your help -
BBC is GEO-blocked.
But I managed to record everything in 1080HD via YouTube.
It's a very simpel process so if you are interested just reply and I will explain you how I have done it.
Lance -
Dear LanceBehind,
I am very anxious to find out how to do it, Please guide me through
THX -
@fhcyip try a VPN such as ExpatShield for iPlayer - http://www.expatshield.com/
N.B. for those looking to download BBC videos larger than 4GB try KSV's Adobe HDS Downloader it works great for me: http://stream-recorder.com/forum/adobe-hds-downloader-t12074.html
Grab the Akamai HDS server URL from the Firefox web developer console, (set filters for "akamai" and "&hdcore")Last edited by Chug a Bug; 17th Sep 2012 at 13:28.
Start Firefox :
Go to www.youtube.com/olympic
Pick your sport and the video you want to download
Open web console (CTRL-SHIFT-K)
Optional - Unselect CSS, JS, & Logging on the menu bar
Type in "m3u8" in the filter on top right
Start the video you want to see
Click the gear icon on bottom right of video and select the quality you want (typically 1080) and you'll see a new m3u8 file appear
Copy this link to CTLR-C
Use this URL for the "-i" option of ffmpeg
Goto Start Type CMD
Move to your FFMEG directory : (for example C: and CD FFMPEG/bin)
Type in : ffmpeg -i (YOUR URL WITH m3u8 at the END (* CTLR V won't work so use right mouse button) -c copy output.ts
Hope this helps
Lance -
Hi. I still do not understand this. I cannot download the Adobe HDS downloader php file. I just get a script of data as it if was a web page but in raw code - not in a format that can be saved.
So what I want is a program that will download the fragments and be able to join them all together as an flv or whatever it is menat to be. Please can you tell me where I can get the actual application file for this HDS Downloader?
Then what am I meant to do? Thanks. -
Problem solved. BTW if you want to conver to AVI instead of MP4 how would you chagne the instruction? Thanks.
Capturing YouTube videos
By henry33 in forum Capturing and VCRReplies: 5Last Post: 7th Oct 2011, 22:38 -
Program to Catch Videos from Internet ( Like Xvideos, for example)?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 28th Jun 2010, 08:30 -
What was your favorite winter olympic event?
By johns0 in forum PollsReplies: 15Last Post: 2nd Mar 2010, 15:25 -
Any Vancouver Olympic observations? 1080i 29.97 sure helps here vs 25.
By edDV in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2010, 18:57 -
deinterlacing olympic games
By vhelp in forum EditingReplies: 38Last Post: 24th Aug 2008, 22:51
