I'm stuck at the RTMPDump stage.
Is anyone using Windows 7 able to help me run the script? Is there an alternative?
Results 121 to 150 of 194
Have you managed to download videos from nbc? I've tried with flash downloaders addons, jdownloader, web console, wireshark, opera cache...
View this thread: How to download flash video RTMP/RTMPE streams using free software
Read after #545
I'm trying to capture the Rhythmic Gymnastic Final in 720p which is located at...
I've been able to download at 480p and can get RTMPdump to start the 720p stream using the code...Code:http://www.bbc.co.uk/sport/olympics/2012/live-video/p00w3312
However, as it's 3hrs 07m 30s it will be over 4GB.Code:rtmpdump -r "rtmp://cp41752.edgefcs.net:1935/ondemand" -a "ondemand?auth=daEcUcPcecab9apaiarasd5asd6bucccIcy-bqlw.U-bWG-HpmFEpwoGBsEvwJ&aifp=v001&slist=secure/800kbps/MP/events/p00w36zy_1344699296295.mp4;secure/480kbps/MP/events/p00w36zy_1344699296281.mp4;secure/1500kbps/MP/events/p00w36zy_1344699296315.mp4;secure/3200kbps/events/p00w36zy_1344699296329.mp4" -W "http://www.bbc.co.uk/emp/releases/iplayer/revisions/617463_618125_4/617463_618125_4_emp.swf" -C O:1 -C O:0 -y "mp4:secure/3200kbps/events/p00w36zy_1344699296329.mp4" -o "720p.flv"
I've tried get_iplayer, however, it can't get it to connect to a 720p steam
I'd absolutely love to have the final in 720p, so if anyone can help I'd be very appreciative. -
Do as I, split the competition in several parts. For example, add -A 0 and -B 800 to the code to download the second 0 to 900
Hi karlinhosmg,
Where do I add "-A 0" and/or "-B 800" to the string I already have into RTMPdump ?
I managed to get just over 4gb so I have some. Can I start from where RTMPdump ended with an errorCode:rtmpdump -r "rtmp://cp41752.edgefcs.net:1935/ondemand" -a "ondemand?auth=daEaEd0cXbMcJcMbGbBa5dIbOc0ctctbSdC-bqlzqh-bWG-BqnFJoEpKDvFpxJ&aifp=v001&slist=secure/480kbps/MP/events/p00w36zy_1344699296281.mp4;secure/800kbps/MP/events/p00w36zy_1344699296295.mp4;secure/1500kbps/MP/events/p00w36zy_1344699296315.mp4;secure/3200kbps/events/p00w36zy_1344699296329.mp4" -W "http://www.bbc.co.uk/emp/releases/iplayer/revisions/617463_618125_4/617463_618125_4_emp.swf" -C O:1 -C O:0 -y "mp4:secure/3200kbps/events/p00w36zy_1344699296329.mp4" -o "720p2.flv"
Kind Regards Angelical_1Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\...\...\Downloads\RTMP>rtmpdump -r "rtmp://cp41752.edgefcs.net:1935/onde
mand" -a "ondemand?auth=daEcUcPcecab9apaiarasd5asd6bucc cIcy-bqlw.U-bWG-HpmFEpwoG
-o "720p2.flv"
RTMPDump v2.4-35-ge0056c5
(c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL
Connecting ...
INFO: Connected...
ERROR: rtmp server sent error
ERROR: rtmp server requested close
mand" -a "ondemand?auth=daEaEd0cXbMcJcMbGbBa5dIbOc0ctct bSdC-bqlzqh-bWG-BqnFJoEpK
-o "720p2.flv"
Connecting ...
INFO: Connected...
Starting download at: 0.000 kB
INFO: Metadata:
INFO: duration 11250.13
INFO: moovPosition 36.00
INFO: width 1280.00
INFO: height 720.00
INFO: videocodecid avc1
INFO: audiocodecid mp4a
INFO: avcprofile 77.00
INFO: avclevel 31.00
INFO: aacaot 2.00
INFO: videoframerate 25.00
INFO: audiosamplerate 44100.00
INFO: audiochannels 2.00
INFO: trackinfo:
INFO: length 11248001.00
INFO: timescale 1000.00
INFO: language eng
INFO: sampledescription:
INFO: sampletype amf0
INFO: length 11250121.00
INFO: language eng
INFO: sampletype avc1
INFO: length 11250139.00
INFO: language eng
INFO: sampletype mp4a
4189096.110 kB / 9810.24 sec (87.2%)
ERROR: RTMP_ReadPacket, failed to read RTMP packet header
4189150.055 kB / 9810.24 sec (87.2%)
INFO: Connection timed out, trying to resume.
Resuming download at: 4189150.055 kB
4189150.055 kB / 0.00 sec
ERROR: Failed to resume the stream
Download may be incomplete (downloaded about 0.00%), try resuming
C:\...\...\Downloads\RTMP> -
For exampleCode:
rtmpdump -r "rtmp://cp41752.edgefcs.net:1935/ondemand" -a "ondemand?auth=daEaEd0cXbMcJcMbGbBa5dIbOc0ctctbSdC-bqlzqh-bWG-BqnFJoEpKDvFpxJ&aifp=v001&slist=secure/480kbps/MP/events/p00w36zy_1344699296281.mp4;secure/800kbps/MP/events/p00w36zy_1344699296295.mp4;secure/1500kbps/MP/events/p00w36zy_1344699296315.mp4;secure/3200kbps/events/p00w36zy_1344699296329.mp4" -W "http://www.bbc.co.uk/emp/releases/iplayer/revisions/617463_618125_4/617463_618125_4_emp.swf" -C O:1 -C O:0 -y "mp4:secure/3200kbps/events/p00w36zy_1344699296329.mp4" -A "0" -B "800" -o "720p2.flv"
how come everyone seems to be able to download NBC videos and i am
seemingly fraught with issues ?
i can't seem to sniff out any rtmp links for the NBC sites and RTMPdumphelper is not exactly helping
i am going to re-try the instructions.Last edited by quackeroats; 17th Aug 2012 at 09:14.
Sorry, trying to understand...
With the steam having failed at 9810.24 seconds... Will I need to redo the stream or can I enter a string to continue the steam from where it failed?
If it be best to create 2 flv files at 7200 seconds (2hrs) each
1. What would the commands be?
2. Do I type the 2nd command in after the first has finished?
3. Do I have to give each a new filename, or will it add it to the existing one?
Kind Regards Angelical_1 -
If your download fails at 9810.24, write the same code (you have to update the .xml):
[QUOTE=karlinhosmg;2180519]rtmpdump will download the same video but starting at 9810.24.Code:rtmpdump -r "rtmp://cp41752.edgefcs.net:1935/ondemand" -a "ondemand?auth=daEaEd0cXbMcJcMbGbBa5dIbOc0ctctbSdC-bqlzqh-bWG-BqnFJoEpKDvFpxJ&aifp=v001&slist=secure/480kbps/MP/events/p00w36zy_1344699296281.mp4;secure/800kbps/MP/events/p00w36zy_1344699296295.mp4;secure/1500kbps/MP/events/p00w36zy_1344699296315.mp4;secure/3200kbps/events/p00w36zy_1344699296329.mp4" -W "http://www.bbc.co.uk/emp/releases/iplayer/revisions/617463_618125_4/617463_618125_4_emp.swf" -C O:1 -C O:0 -y "mp4:secure/3200kbps/events/p00w36zy_1344699296329.mp4" -A "9810.24" -o "720p2.flv"
Yes, rename the new file. I tried some times to resume the download but always failed so you have to download the video in several parts -
anyone has this issue?Code:
ffmpeg -i http://www.youtube.com/api/manife st/hls_playlist/id/016fd0b7d484de1f/itag/95/source/yt_live_broadcast/ratebypass/ yes/cmbypass/yes/playlist_type/CLEAN/maudio/1/pmbypass/yes/upn/7xLLhfZWTNs/sver/ 3/ip/173.208.33.244/ipbits/8/expire/1345287156/sparams/ip,ipbits,expire,id,itag, source,ratebypass,cmbypass,playlist_type,maudio,pmbypass/signature/413FF2FF1E792 91B0E8AD9072F5C6E1E875B6805.10D6175A0FE729320E293A6259A3CB098A99DFDC/key/ck1/fil e/index.m3u8 ffmpeg version N-35709-g7d531e8, Copyright (c) 2000-2011 the FFmpeg developers built on Dec 12 2011 13:50:00 with gcc 4.6.2 configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger - -enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable- libxvid --enable-zlib libavutil 51. 32. 0 / 51. 32. 0 libavcodec 53. 43. 0 / 53. 43. 0 libavformat 53. 24. 0 / 53. 24. 0 libavdevice 53. 4. 0 / 53. 4. 0 libavfilter 2. 53. 0 / 2. 53. 0 libswscale 2. 1. 0 / 2. 1. 0 libpostproc 51. 2. 0 / 51. 2. 0 [http @ 003090C0] Key 'pb' not found. [http @ 003090C0] Error parsing options string ,ipbits,expire,id,itag,source,rat ebypass,cmbypass,playlist_type,maudio,pmbypass/signature/413FF2FF1E79291B0E8AD90 72F5C6E1E875B6805.10D6175A0FE729320E293A6259A3CB098A99DFDC/key/ck1/file/index.m3 u8 http://www.youtube.com/api/manifest/hls_playlist/id/016fd0b7d484de1f/itag/95/sou rce/yt_live_broadcast/ratebypass/yes/cmbypass/yes/playlist_type/CLEAN/maudio/1/p mbypass/yes/upn/7xLLhfZWTNs/sver/3/ip/173.208.33.244/ipbits/8/expire/1345287156/ sparams/ip,ipbits,expire,id,itag,source,ratebypass,cmbypass,playlist_type,maudio ,pmbypass/signature/413FF2FF1E79291B0E8AD9072F5C6E1E875B6805.10D6175A0FE729320E2 93A6259A3CB098A99DFDC/key/ck1/file/index.m3u8: Not enough space
URL: http://www.nbcolympics.com/video/judo/mat-b-w-57kg-m-73kg-elim-through-qf.html -
This is a great forum. Thanks to all the contributors!
I have found the get_iplayer to be the easiest method. However I have two problems with it:
1. Even when it gets the flashhigh1 mode, the video is only 640x360.
2. Not all events seem to provide the option of HDS and RTMP, some are HDS only (e.g. http://www.bbc.co.uk/sport/olympics/2012/live-video/p00w2wq0)
Which lead me back to the AdobeHDS.php method. So to make the HDS download an easier task I have written a python script to sniff the network for the HDS manifest URL and alter it to use the high quality 3200kbps (1280x720) version. Then pass this manifest on to AdobeHDS.php which will do all of the heavy lifting (downloading the fragments and assembling into a .flv file).
See attached london_hds_get.zip -
I've only tested this on my Linux machine with PHP 5.x and Python 2.x. I see you are running Windows... it should work with Windows too.
There are some instructions for setting up PHP and AdobeHDS.php on Windows here:
http://stream-recorder.com/forum/adobe-hds-downloader-t12074.html
You'll also need to install Python (grab a 2.x version):
http://www.python.org/getit/
WinPcap 4:
http://www.winpcap.org/install/
and the Python library pcapy:
http://oss.coresecurity.com/projects/pcapy.html
Then you can just run my script as per the instruction (instructions are provided in the file header as comments). -
Yes well that is to be expected, the flashhigh mode is only 640x360, you want either flashvhigh or flashhd, see thread post here.
Worked fine for me, see below:
Just use get_iplayer, much easier.Code:C:\Program Files (x86)\get_iplayer>get_iplayer http://www.bbc.co.uk/sport/olympi cs/2012/live-video/p00w2wq0 --mode=flashhd --raw get_iplayer v2.82, Copyright (C) 2008-2010 Phil Lewis This program comes with ABSOLUTELY NO WARRANTY; for details use --warranty. This is free software, and you are welcome to redistribute it under certain conditions; use --conditions for details. INFO: Episode-only pid detected INFO: Trying pid: p00w2wq0 using type: tv INFO Trying to stream pid using type tv INFO: pid not found in tv cache INFO: Checking existence of default version INFO: flashhd1,flashhd2 modes will be tried for version default INFO: Trying flashhd1 mode to record tv: Olympic Shooting - London 2012: Men's 1 0m Air Rifle INFO: File name prefix = Olympic_Shooting_-_London_2012_Mens_10m_Air_Rifle_p00w2 wq0_default RTMPDump 2.4 git-b627335 2011-7-23 (c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL Connecting ... INFO: Connected... Starting download at: 0.000 kB INFO: Metadata: INFO: duration 2872.76 INFO: moovPosition 36.00 INFO: width 1280.00 INFO: height 720.00 INFO: videocodecid avc1 INFO: audiocodecid mp4a INFO: avcprofile 77.00 INFO: avclevel 31.00 INFO: aacaot 2.00 INFO: videoframerate 25.00 INFO: audiosamplerate 44100.00 INFO: audiochannels 2.00 INFO: trackinfo: INFO: length 2872001.00 INFO: timescale 1000.00 INFO: language eng INFO: sampledescription: INFO: sampletype amf0 INFO: length 2872761.00 INFO: timescale 1000.00 INFO: language eng INFO: sampledescription: INFO: sampletype avc1 INFO: length 2872774.00 INFO: timescale 1000.00 INFO: language eng INFO: sampledescription: INFO: sampletype mp4a 2688.682 kB / 6.60 sec (0.2%)
did any one manage to use rtmpdump from outside uk ? i keep getting this error:
it is strange that i can view the video but cant use the rtmpdump ! could you guys help me fix this problem ?thanksCode:(c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL Connecting ... ERROR: RTMP_Connect0, failed to connect socket. 10060 (Unknown error)
I don't know. When i tried to download the video behind a proxy i had the same problem. You have to search a uk dns, it's easy
Thanks guys now i get this error after download starts :
Code:ERROR: RTMP_ReadPacket, failed to read RTMP packet body. len: 71310 46654.640 kB / 292.84 sec (3.1%) Download may be incomplete (downloaded about 3.10%), try resuming
karlinhosmg can you tell me how i can resume or be able to download the whole thing ?only small percentage gets downloaded before i get the above error! -
all was working well with get_iplayer then today I get an error message. Anyone seen this and know a solution?
I enter the command "get_iplayer http://www.bbc.co.uk/sport/olympics/2012/live-video/p00w31zk --raw --mode=best"
And see this error:
INFO: File name prefix = Olympic_Triathlon_-_London_2012_Mens_Triathlon_p00w31zk
_default
RTMPDump 2.4 git-6230845 2011-9-25
ERROR: Unexpected start of file, error in tag sizes, couldn't arrive at prevTagS
ize=0
INFO: Command exit code 1 (raw code = 256)
WARNING: Retry recording for 'Olympic Triathlon - London 2012: Men's Triathlon (
p00w31zk)' -
can i ask, has anyone successfully downloaded 720p from get_iplayer?
Capturing YouTube videos
By henry33 in forum Capturing and VCRReplies: 5Last Post: 7th Oct 2011, 22:38 -
Program to Catch Videos from Internet ( Like Xvideos, for example)?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 28th Jun 2010, 08:30 -
What was your favorite winter olympic event?
By johns0 in forum PollsReplies: 15Last Post: 2nd Mar 2010, 15:25 -
Any Vancouver Olympic observations? 1080i 29.97 sure helps here vs 25.
By edDV in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2010, 18:57 -
deinterlacing olympic games
By vhelp in forum EditingReplies: 38Last Post: 24th Aug 2008, 22:51
