I have a PCI-E HD capture card in my desktop, it records through HDMI
Is it possible to split hdmi and record? for example, I want to record games from my PS3 as I play them on my TV, could I run HDMI from the ps3, to a splitter, then into my tv and once again in the same splitter to my pc?
If so would something like either of these work? http://www.amazon.com/HDMI-3-In-1-Out-Switch-Cable/dp/B0018DQYQ2/ref=sr_1_1?ie=UTF8&qi...=hdmi+splitter
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10113&cs_id=1011303&p_id=...seq=1&format=2
Results 1 to 12 of 12
Isn't output from the PS3 protected by HDCP? Will your HDMI capture device record that? I'm only aware of one device that will and only with a loophole in early releases of the driver.
Yes I forgot to mention that, ps3 is protected but my device is hdcp compliant, I can currently record from it just fine just plugging it into the pci card
1. http://www.amazon.com/HDMI-3-In-1-Ou...=hdmi+splitter
No. That device is a switch not a splitter. A switch allows multiple sources to share one HDMI connection, but only transmits one source at a time. A splitter allows someone to connect one source to multiple devices at the same time. Switches are normally one-way, and do not function as splitters.
2. http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10113&cs_id=1011303&p_id=...seq=1&format=2
No. Passive HDMI splitters usually don 't work with HDCP compliant devices like the PS3. This powered splitter is a better choice: http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10113&cs_id=1011306&p_id=...ormat=2&ref=cjLast edited by usually_quiet; 28th Jul 2012 at 18:37. Reason: grammar
http://www.ebay.com/itm/HDMI-Splitter-Amplifier-Multiplier-1-x-2-Female-/300731237110?...item4604fa82f6
Just wondering if something like this would work? After shipping its half the price as the one on monoprice
it says Output Video: HDMI 1.3 + HDCP1.0/1.1/1.2 under specs -
A passive splitter shouldn't work with HDCP protected sources. Before the source starts transmitting it requires a handshake with the receiving device wherein they exchange cryptographic keys. With a passive splitter both devices would respond resulting in a handshake failure. Even if only one device responds the other device wouldn't be able to decrypt the resulting signal.
Just wanted to post and say thanks
I took a chance and ordered the one I linked from ebay (HDMI Splitter Amplifier Multiplier 1 x 2 Female)
was the cheapest I could find and I received it in the mail today, it works great and physically seems durable
I've got no quality loss and no problems recording
question about passive hdmi splitting
By maca in forum DVB / IPTVReplies: 0Last Post: 7th Jul 2012, 13:45 -
Splitting DVI and HDMI signals. Veterans please check my setup
By anubis13 in forum ComputerReplies: 9Last Post: 21st Jan 2010, 16:14 -
Humax PVR 1000c blocks HDMI splitting.... hack-around?
By x7dude in forum DVB / IPTVReplies: 5Last Post: 4th Oct 2009, 11:32 -
Capturing from HDMI
By koberulz in forum DVB / IPTVReplies: 2Last Post: 14th Dec 2008, 07:42 -
Capturing Thru HDMI
By Soreen in forum Capturing and VCRReplies: 2Last Post: 22nd Feb 2008, 03:27
