I'm not goin to make as good as in video.
I'm going to make a DVD menu with some image as the background with addition a video playing 30 sec or so just like the video above
is there a way to make it via DVD styler?
Perhaps something along these lines if I understand what you are getting at correctly.
I made a small demo you may download here http://www.mediafire.com/?c0eikvkkvec906u
It uses your YouTube video as a "First Play" and a frame from that video as menu background. The menu has 6 buttons that merely play the same small title.
Mount it and play it with PowerDVD, Total Media Theater or the like (just saw VLC skips the First Play)Last edited by videobruger; 28th Jul 2012 at 00:46.
Yeah what I want to say is using frame video as background is that possible in DVD styler?
you make that? damn your good!! teach me sometimes -
Officially I don't think so. However if you simply change your your static menu background with a video clip it'll play the clip and then freeze the background at the last frame, ie don't loop.using frame video as background is that possible in DVD styler?
You may download an example with a one-button menu here http://www.mediafire.com/?027kmib8u9zxb1d
AVStoDVD supports video clip as menu background. How it works I don't know - I've only used static backgrounds.
How do I create a DVD Menu
By RKM1552 in forum Authoring (DVD)Replies: 6Last Post: 23rd Feb 2010, 12:19 -
How do I create a DVD menu?
By RKM1552 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Feb 2010, 06:42 -
What program do you use to create a menu for DVD
By Cazz in forum Authoring (DVD)Replies: 6Last Post: 24th May 2009, 12:31 -
create a dvd menu from iso image
By DSLGuy in forum Authoring (DVD)Replies: 3Last Post: 19th May 2008, 09:30 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
