Need to convert ProRes to 422 HD MPEG2 program stream.
Can FF MPEG do this? I can't seem to find the settings to make this happen.
Am I out of luck?
Results 1 to 9 of 9
Yes, ffmpeg or ffmbc can do it
ffmbc has xdcamhd422 presets you can use
http://code.google.com/p/ffmbc/wiki/XDCAMHD422Encoding
just enter .mpg if you want MPEG2-PS , and use the correct vtag for your input video
e.g for 1080p24 , assuming stream copied audio
Code:ffmbc -i input.mov -target xdcamhd422 -vcodec copy -vtag xd5d output.mpg
I don't need XDCAM .. just MPEG2 HD 422 I would like to be able to adjust the bitrate to maybe 15 or 18Mbps CBR for our Playout server.
From what I understand I can't insert Closed Captioning into a XDCam file. -
Are you sure? Sorry, what is this "playout server?"
xdcamhd is pretty industry standard stuff @ 50Mb/s CBR 422 MPEG2 . It's the minimum bitrate required for most submissions . 15-18Mb/s CBR isn't accepted in most places (and since you're using 422, it's obviously not intended for a final format)
You can use -vcodec mpeg2video and -b for bitrate, and -pix_fmt yuv422p to force 422, but I can't recall how to force CBR or insert null packets with ffmpeg/ffmbc
I don't know about Closed Captioning, maybe you can start another thread asking about thatLast edited by poisondeathray; 27th Jul 2012 at 13:10.
We are using PLAYBOX AirBox. http://www.playbox.tv/go.idecs?i=286
And Closed Captioning compatibility is a big issue.
Right now CC for HD files in Playbox only works on MPEG2 files they are working on getting H.264 as we speak but for right now I need a solution for MPEG2 HD to get our files on the air. -
You're just using xdcam preset for the video encoding (it normally doesn't come in mpeg2-ps, it usually comes in .mxf, .mp4 or .mov containers)
I think CC should be compatible in mpeg2-ps (.mpg) or transport streams, but I don't know how to mux them in
In order to get real CBR, the buffer size, minrate and maxrate need to be set properly, otherwise you get underflow or overflows . I don't know how to calculate this for mpeg2
You can try asking the ffmpeg dev's, or maybe try at doom9 or doom10 forums. The ffmbc developer is very knowledgable and actively involved in the industry you can try the ffmbc board as well -
apparently fmbc is for Windows and Linux only. I am on a Mac.
I really wish Apple would just support MPEG2 encoding in QT. The MPEG2 playback component is only good for decoding. -
I think you should be able to compile it for mac, as you can compile ffmpeg for osx as well . There might be some precompiled mac binaries floating around if you search google
You might be able to do it with ffmpegx , or iffmpeg (these are GUI's around ffmpeg) , but I don't know if they give you enough control over the settings
They were talking about implementing captions in ffmbc in the past, but it looks like work in progress still
https://groups.google.com/forum/?fromgroups#!topic/ffmbc-discuss/iy_gAAJxW4U -
You should have MPEG2 encoding with Apple's "Compressor".
Apple Prores 422 in MPEG Streamclip for Mac
By blanco in forum MacReplies: 5Last Post: 7th Jul 2011, 01:05 -
Best way to convert ProRes into a format for Handbrake input?
By bugeyes in forum Video ConversionReplies: 0Last Post: 6th Jul 2011, 13:26 -
Most practical method to convert from ProRes to AVCHD
By mikeveli20 in forum MacReplies: 0Last Post: 12th Mar 2011, 15:21 -
ProRes 422 (LT) 4.29GB wont open
By RenderFi in forum MacReplies: 8Last Post: 11th Dec 2010, 09:54 -
need MPEG2 Transport stream and Program stream profiler
By afarun in forum ProgrammingReplies: 3Last Post: 23rd Aug 2007, 01:06
